Where can i find older 12.11 AMD drivers?
16 Mar 2012
Chelmsford,Essex,UK
Hi i am having a wierd issue as mentioned before, now im not sure whether its the latest Afterbuner or 12.11 drivers but my overclock goes back to stock and i can't reapply it, not according to afterburner monitor anyway.
Afterburner accepts it but the monitoring says im at stock 1000/1375 when i should be at 1150/1650.
So there were different versions of the 12.11 drivers but i can't find them and perhaps a different version of Afterburner might help.
Thanks
Anyone find a link to the beta 8 version i can't find one keeps coming up with beta 11.
Thanks
Thanks mate. From what I have seen in the beta 11 thread in this section there has been low gpu usage, lock ups, crashes and BSOD's which beta 8 doesn't have. As its the main game I'm playing at the moment I might as well play it safe!
Seems a few people have had problems with beta 11 in BF3 in this thread here though I do see you have noted you have no problems with them :)
http://forums.overclockers.co.uk/showthread.php?t=18467975&highlight=12.11+beta+11+bf3&page=6
Also this thread:
http://forums.overclockers.co.uk/showthread.php?t=18468362&highlight=12.11+beta+11+bf3
The only problem like i say is when i applied an overclock in Afterburner and i didn't notice straight away as i was playing small BF3 maps,ie Ziba tower so left my 7970 at 1000/1375 then when i applied OC of 1150/1650 for bigger maps ie Aftermath it would apply fine and display the right clock in game using the Afterburner overlay but then i would start a game and then notice on the overlay it had dropped to stock 1000/1375.
Once this has happened no matter what i tried the overlay wouldn't display the OC! But this wasn't confined to BF3 once it happened the OC wouldn't display in Farcry 3 either.
So wasn't sure whether it was Afterburner of the drivers.
