Spec me an upgrade
Again, because I can't read :D
And I thought that, it does look nicer than the RAM in my spec, it is faster, and it does have a lifetime warranty, you are quite right :)
I have heard some peoples experiences with Patriot memory though and it doesn't sound too good, though I think they were about the Black Mamba series.
You actually linked the same Z77M-D3H mobo twice lol As I said the Z77-D3H is the better mobo and I explained why, I'm sure you meant to link it. I've used it in several builds over the last few days\weeks. I actually used the Corsair Vengenace DDR3 RAM in cerulean blue which matches perfectly with the mobo. It didn't cost any more to do so and these little touches make all the difference in my eyes.
Oh boy, this is a bad day for me :( i've fixed my original post now :)
I do like the vengeance RAM, I was a little disappointed that I couldn't overclock mine at all, but I think it may be because it is 'incompatible' with my motherboard.
You fixed it? You mean you ripped off my spec.....cheeky.
All i did was enable the XMP profile, that's then set to the best timings job done
You could go with this if you don't want to Change Mainboards .
CPU
http://www.overclockers.co.uk/showproduct.php?prodid=CP-253-AM&groupid=701&catid=1967&subcat=1943
SSD
http://www.overclockers.co.uk/showproduct.php?prodid=HD-009-CR&groupid=701&catid=2104&subcat=
They would cost £ 180 together and maybe buy another another 4 gbs or ram or a CPU cooler with the left over money .
He could but the CPU is too dear for what it is, the 955 was going for £60ish a little while back, might as well buy one second hand as people are upgrading to Ivy. It wont be better than a SB or IB i3 and phenoms consume more power. I'd also suggest the samsung 830 SSD over the Crucial M4
