Macbook won't boot in to OSX
21 Dec 2009
Gateshead
I bought a Retina Macbook pro in September. No recently when I try to boot the apple logo comes up with the loading bar underneath but then the Macbook just cuts out. I've tried using the restore boot option but that won't work either. The only option I have is to use the windows boot camp install I have.
Anyone got any suggestions or is it a trip to the apple store?
Yeah I've done that but when I go through the recovery process it says there isn't a HD to recover to
What's showing in disk utility? Might be the partition has corrupted? Go through recovery/disk utility if it's there and see if the Macintosh HD partition is greyed out or simply not there.
Try doing an Apple hardware check to see if there is an error with your ssd.
Hold down 'd' when your mac boots and let the test run. If this doesn't work hold down 'option d' to run the test from the internet rather than of the local disk.
I've just verified the disk and its acknowledged there's an error with it. I've tried repairing it but it says it can't be repaired. Should I just format it now and see if that fixes things?
I'd say it's the next best step as long as you are happy with all your data definitely being wiped.
The SSD is partitioned half and half OSX / Bootcamp, formatting will only erase all the data on the OSX partition is that right?
Assuming you only click on the Macintosh HD partition and erase it, if you click on the hard drive and repartition, that will wipe everything.
If hardware test is reporting errors on the disk then use something like Data Rescue 3 to recover as much as you can then get it replaced under warranty via Apple.
