I'd rather get a HD7950/7970 or a next gen gpu when they come out.I'm thinking of selling on my gigabyte 7850 in favour of a reference 670. After playing Planetside 2 i think i need a bit more power. How much of a boost will i see with a 670?
This is mine. Whats going on with mY GPU model??
will this effect anything? This is running on a iMac 27 as a primary monitor.
*snip*
Seems below average to me. I get 7663 (GPU 7558, Physics 8173, combined 7752) with a 2500K at 4.4Ghz and MSI 7850 @1150/1350. Are you using the latest 12.11 drivers?
no, using 12.10... What do you make of it Alf?
I'm getting P6821 with the 7850 at 1200/1350 and a 3570K at 4.4Ghz, not quite sure where you're getting the extra grunt. Do you have Virtu MVP enabled Alf?
You know I thought my score was a bit high - I'll re-check and see what's going on. I don't have Virtu MVP enabled - I don't think it works with Sandybridge CPUs.
Ok just ran 3DMark11 again, at default, and got P7658. http://www.3dmark.com/3dm11/5206084. I haven't benched this card for a while, and now I think about it that does seem higher than I remember getting previously (maybe around 6800?). Unless I'm missing something obvious, the only thing I can think of is that I recently upgraded to the latest beta 12.11, which I think was supposed to give a pretty large performance increase.
