1300-1500 Budget gaming pc
nice spec as always Doomedspeed, i'd alter the teamgroup ram tho, i have them and they suck, had 2 faulty sets upto yet so on my third rma now.
doesn't fill me will joy, ho ho ho :)
must sell a lot to have so many faulty
oo i didnt see phanteks started doing a 120mm version
looks pretty^^
I know, isn't it... Pre-order at the moment though..
Oh, Thats the first Bad thing i have heard about them, though it is quite a problem.
I only really specced it as it was White though.. 16GB of XMS3 (which i have) is the same price. That would be better. :)
pre built if you dont want the agro,
Intel X79 Sandybridge - E 10300i Configurator - Workstation & Gaming PC
- TX650V2 Bronze CP-9020038-UK for S.I.
- Onboard Sound Card (ZERO COST)
- OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
- Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW)
- Intel 330 Series 60GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail
- HIS HD 7950 3072MB GDDR5 PCI-Express Graphics Card (H795F3G2M) with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games
- GeIL Enhance Corsa 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit (GEC316GB1600C9QC)
- Gigabyte X79-UD3 Intel X79 (Socket 2011) DDR3 Motherboard
- Intel Liquid Cooling Solution CPU Cooler (Socket LGA1155 / 1156 / 1366 / 2011)
- Stage 4: Overclock of CPU/Memory - 25% Overclock (Proceesor speed x1.25 / Max Attainable RAM SPEED)
- Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor - Retail
- Antec 300 Three Hundred Ultimate Gaming Case - Black
Total : £1,422.48
went for an i7, more power and budget is good enough, also picked amd card but not the very fatest, not really needed as 7950 will do all you need for a year or so at least, then the next one out now will be half price or less so can always upgrade it then, saves the money now for top end other bits
or to build it yourself but not to overclock yourself,
http://www.overclockers.co.uk/showproduct.php?prodid=BU-134-OE&groupid=43&catid=2384&subcat=2288
Krypton Z77 SNIPER" Intel Core i5 3570K 3.40GHz @ 4.60GHz DDR3 Ivybridge Overclocked Bundle
Gigabyte ATI Radeon HD 7970 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games
Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001)
"Krypton Z77 SNIPER" Intel Core i5 3570K 3.40GHz @ 4.60GHz DDR3 Ivybridge Overclocked Bundle
Options applied to the above product:
Gigabyte Z77-G1-Sniper M3 Intel Z77 (Socket 1155) DDR3 Micro ATX Motherboard
Standard Build Systems - Approximately 5-7 working days
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W)
onic G series 550w '80 Plus Gold' Modular Power Supply
Pioneer 24x Internal DVR-S20LBK DVD Rewriter including Labelflash - Retail
Sub Total : £944.07
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £13.75
VAT is being charged at 20.00% VAT : £191.56
Total : £1,149.38
i7 3770k retail
HIS IceQ Boost (£229)
Samsung 256GB 840 PRO SSD
Seasonic X-Series 850W moduler gold PSU
ASRock Extreme4 Z77 mobo (trying to keep a black and white colour scheme:D)
NZXT Phantom Enthusiast Full Tower case
Seagate Barracuda 3TB 64mb cache 7200rpm storage HDD
Asus Xonar D2X PCI-E Soundcard
Phanteks PH-TC14CS CPU Cooler Black
TeamGroup Elite 16GB (2x8GB) RAM
Asus 24x DVD±RW DRW-24B5ST SATA ReWriter - Black (Retail)
Total : £1,357.57
Can't buy more than one HIS IceQ as it's 'on offer'
It really is the only card to buy at the moment. Nvidia cards do have benefits for editing tasks with CUDA etc but it depends what you are doing, which programs etc and someone who knows all the programs well and exactly how they benefit would be better suited to advise if Nvidia is essential for you. If it isn't then deffo go for a 7950 if it is then tbh I wouldn't bother with a 680 I'd just get a 670 like:
EVGA 670 FTW:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-195-EA
Gigbayte Windforce 3x:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-095-GI
YOUR BASKET
1 x Asus GeForce GTX 670 DirectCU II 2048MB GDDR5 PCI-Express Graphics Card £339.95
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £245.99
1 x BeQuiet Dark Power Pro P10 850W '80Plus Platinium' Modular Power Supply £189.95
1 x Gigabyte Z77X-UD5H Intel Z77 (Socket 1155) DDR3 Motherboard £173.99
1 x Crucial RealSSD M4 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT256M4SSD2) £164.99
1 x NZXT Switch 810 Big Tower Case - Matt Black £149.99
1 x Corsair Vengeance Low Profile 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (CML16GX3M2A1600C10) £79.99
1 x LG BH10LS38 10x BluRay-RW / 16 x DVD±RW Lightscribe Drive - Black (Retail) £79.98
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) £78.98
1 x BeQuiet Dark Rock Pro 2 CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £61.99
Total : £1,583.50 (includes shipping : £14.75).
The case is really going to be you personal preference, so you can certainly cut a few pounds off the build by choosing a less expensive case that is more to you liking.
NZXT Pros: It is big (you probably will not be able to fit it under a desk - will require at least 62cm clearance). The size ensures that the Large air cooler easily fits, as does the graphics card and it is really easy to build in.
NZXT Cons: It is Big. The case fans are a little noisy.
The PSU is probably one of the best there is, quiet, good quality cables and fittings. I bought a seasonic one at the same time and this definitely feels better. However if you need to shave off a few pounds you can get a less expensive PSU.
