Hello there. Seeing as it was Christmas yesterday, I got my hands on a wee bit of cash. Recently, although it's been fine for about 6 years, I've been noticing that my old CPU can't really keep up with modern games all that well. It's consistently at between 80 and 100 degrees in heat according to internal temp, even after cleaning out the fan and heatsink with compressed air, and I don't even have it overclocked.
I've been thinking about upgrading my PC for a while now, and for a few months I've been looking at some parts on OCUK, but I don't know how well they will work together with the older parts which I already have and wish to keep.
The idea is that I keep my GFX Card and Hard-drives, and upgrade everything else.
For around about £250.
Unfortunately, I don't have access to my PC at the moment, due to being home from uni from the holidays and it being left in halls (the trials of a struggling humanities student, I know). I normally run a quick Dxdiag to check that stuff, though I should really have it saved elsewhere.
I do know that the CPU I wish to replace is one of the the AMD Athlon dual core processors from a few years back, and my Graphics card is ATI/AMD.
In any case, the parts I've looked at from OCUK are as follows.
Motherboard, CPU and RAM.
Case
Now in terms of optical drives, I'm not sure if I want to go for a BD-Rom/DVD-rom, or if I want an DVD-RW drive. I suppose it might be handy to be able to write DVDs since I have a PS3 for Blu-ray watching, and computer disks (though I normally buy things on steam anyway) don't seem to be making the jump any time soon. However, I'm not sure on that front, but from what browsing I've done, both options will end up costing roughly the same amount.
The other thing is PSUs. I'm not sure what wattage to go for, though I think 500 will be enough. There are two corsair ones which I like the price and look of, for the same price. However one is modular and one is not. I'm unsure which I want to go for, so advice on these:
Modular
Non-modular
Would be appreciated.
There are some other things I would like to ask too.
Exactly how much trouble am I liable to be in if I try to use old hard drives with a new CPU? There seems to be some debate about whether it's a viable thing to do. Apparently as long as I'm not going from IDE to SATA I shouldn't have an issue - and both my HDDs are SATA (my optical drive is IDE which is why I'm replacing it). The version of Windows 7 I run is not OEM so there's no issue there.
In addition, I'm nervous about whether these parts will all work together, since I only have very limited experience building PCs - the current one I have was a home build with help from my father four and a half years ago.
Any and all help and suggestions would be appreciated, and as soon as ma be I will get the details of the parts which I wish to keep.
Case
Modular
Non-modular
