I'm a little puzzled about the age criteria, having had a few rides in a 10 plate Elise, and both driven and been driven in an 09 plate M3, I know which I'd be hankering after for that "special" feel, have you driven an M3 OP? - I get the feeling you have not perhaps...,
I was a bit "meh" about them until a mate bought one......
Age & miles can mean little in terms of condition - just look up Fox's 200k 2001 Model e39....
As I say in my initial reply, get one sub 60k,extended BMW warranty - which is akin to a new car warranty afaik - from a BMW dealer, private plate if such a thing matters to hide its age, detail, job done!
Why did you get the fiesta if you were going to chop it in within a year? or company car or something?
Why does it need to be '11 plate or newer, out of interest? If you're more flexible on age you open yourself up to a vast selection of cars.
If I had those choices I'd go for an M135i every time. The '86 would also be a great choice but no match to the BMW in terms of commuting comfort or outright pace.
I already explained above. I didn't really want to argue my motivations or criteria, just more wanted opinion on the cars that fit! I guess you have to expect that here though, so I've answered.
I hear what your saying.
Despite this, try one. You said yourself, you love the sound of a V8, I'm no fan of current BMW l
I really don't get the age requirement, a low mileage e90 M3 08 plate for example, comes in under budget
If newer = better just find whatever brand new cars = exactly your budget and off you go. If that doesn't appeal, may be newer doesn't = better!![]()
Thanks for the input - the M135i has much more power, but no LSD and it's a bit chunkier. Do you think it would it be as fun to drive? I'm not old, so comfort isn't paramount....
I'll test both myself, wonder if anyone here has driven the M135i? It is a very ugly beast though, but I'm not buying to pose.
Chris Harris rates it very high and says unless you're spending a lot of time on track then the lack of LSD isn't too much of an issue. I imagine it'll be a lot of fun to drive too, having been only a passenger in one it's difficult to say what it'll be like compared to an '86.
Go drive both and see for yourself, we all like cars to be different. I'd still say that for commuting the BMW is the better choice. It's a turbo so will offer loads of usable power where the '86 you'd have to rev it hard to get rewards, plus the BMW will be a nicer place to sit and will be built better as well as hold its value a lot better.
Snip.
How far is work? I commute 6 miles through town in my VX every day.![]()
The 86 is a turbo too!![]()
It's not. Maybe could do with it for power but would lose that NA responsiveness I guess.
Peak torque is something silly like 7k RPM, so I imagine you'll need to rag it a little as Chris hinted.
How do you find the VX? Basically an Elise so I'm curious!
I've just edited my post above. Other things that drive me mad is the ride height. Although standard is not quite high enough for a lot of ramps and it feels like I'm constantly picking up my numberplate from the road.
The trade off from having such a stupid car is that once you've got through the winter they are great fun in the summer, has an amazing owners club and steering feel that is unmatched by the comfortable alternatives.
Get rid of the stupid 11 plate requirement, it cuts down a lot of options. You can get perfectly conditioned, low mileage, older cars with comprehensive warranties.
Just my 2p.
Thanks - there are speed bumps around the corner so that could be a pain in the backside. It is a bit in my current car tbh. Elise may be too raw as a daily for me then...
Thanks also - you're certainly not alone in that opinion so I have to respect that. I'm opening my options a bit, but I'm not going too old for the same 'stupid' reasons mentioned.
