I've got an odd question.
I moved into my house in September and I had to connect the existing analogue aerial in the attic to the tv point in the lounge. Hooked up my tv, panny st50, and everything works fine.
I now want to extend that point to the other side of the room. I've ran a cable behind the skirting to another tv point I cut in the wall and added a plug to the other so it can fit into the original tv socket.
When I plug the tv in it comes up with no signal. I've checked the connections and everything is fine. I've got a signal booster in but that doesn't make any difference.
The only thing I can see that's different is the cable itself as the new cable is termed as a digital coaxial cable with gold connections rather than the original analogue coaxial cable with silver connectors.
Would the change in cables and connectors make any difference?
