29 Dec 2012 at 15:04 #1 djkav djkav Soldato Joined 28 Aug 2006 Posts 3,003 I finally took the plunge and stuck that superhub into modem mode. Is there any particular settings I need to sort out for happy internet. I game and steam, stream etc. I sorted out the WiFi security and local security. Thanks.
29 Dec 2012 at 18:36 #2 Steveocee Steveocee Soldato Joined 5 Nov 2011 Posts 5,658 Location Derbyshire Only advice I would give is set google DNS instead of leaving blank to Virgins /-)
29 Dec 2012 at 19:07 #3 FerretBoy FerretBoy Soldato Joined 18 Oct 2003 Posts 3,731 Don't use the QoS unless you really need it as you loose the hardware NAS functionality
29 Dec 2012 at 20:17 #4 djkav djkav Soldato OP Joined 28 Aug 2006 Posts 3,003 I take it I can hook up a USB drive and use it like a NAS?
29 Dec 2012 at 20:44 #5 BloodyL BloodyL Soldato Joined 18 Oct 2002 Posts 3,083 Location In here and out there. FerretBoy said: Don't use the QoS unless you really need it as you loose the hardware NAS functionality Click to expand... QoS breaks the hardware NAT, the NAS works just fine. djkav said: I take it I can hook up a USB drive and use it like a NAS? Click to expand... Yes, you can plug 2 USB devices into it and use it like a NAS.
30 Dec 2012 at 08:07 #6 FerretBoy FerretBoy Soldato Joined 18 Oct 2003 Posts 3,731 Sorry I meant to type NAT
31 Dec 2012 at 21:41 #7 djkav djkav Soldato OP Joined 28 Aug 2006 Posts 3,003 I'm a little confused by the Dual band 2.4 and 5ghz. Do I give them both the same SSID, or do i give them different SSIDs and connect whatever device to which on suits best?
1 Jan 2013 at 01:31 #8 tigerstyle tigerstyle Soldato Joined 18 Oct 2002 Posts 8,968 Location UK Treat them as two different networks
