Ivy vs Zambezi vs Vishera (i5 3570K vs FX-8120 vs FX-8320)
those wanting to run arma 2 benchmarks its in single player/ scenarios ;)
Did you see my post #84 ref. settings used in your chart?
Damn, no, it is also GPU limited by my 6950 at 1680 x 1050 at very high settings. To do these benches, I would need a better card.
just seems odd that you benched games nobody literally plays :p
Thats funny. Reason being I was thinking about this the other day checking out whats new to AMD's drivers, then I read this rubbish... and chuckled.
RESOLVED ISSUES
This section provides information on resolved known issues in this release of the AMD Catalyst 12.10 software suite.
Resolved Issues for the Windows 8 Operating System
Enemy Territory Quake Wars - performance affected when run at high resolutions
Wolfenstien - performance affected when run at high resolutions
System hangs when disabling Eyefinity
World of Warcraft - Mists of Pandaria experiences graphical corruption when anti-aliasing is forced to 2X or higher
Is Vishera worst than Zambezi?
Check it on my blog...
Greetings,
your blogger Fr4nc
same as in chart ;)
my 955 was about same as that chart aswell pretty much spot on (why i linked it )
I must be being extremely stupid today. All I asked was what resolution and settings you are using. I could have much higher framerates at low res than that chart. I am also GPU limited at these higher resolutions, as you would have been be on a 6950 also.
Therefore how can you make this comparison relevant to your argument that all AMD processors suck at ARMA. As far as I can tell it is very playable at high detail.
your blogger Fr4nc
No it's not, I get 4965MB/sec. Admittedly at 4.9GHz, must stop feeding the trolls.
Yes the video card is maxing out before the CPU's run out of grunt.
Of course you knew that :rolleyes:
If your trying to show CPU performance differences in gaming then you have to make sure the GPU isn't the bottleneck.
Perhaps he could go begging to the shop he keeps advertising in the blog and get another card to crossfire with.
Also 4.7Ghz is not a 24/7 overclock for PD.
Unless you never ever stability test it.
4.7Ghz could easily be a stable overclock of PD, I have a BD running 4.75Ghz atm, (I raise and lower depending on the weather, odd i know) It would happily go up to 5Ghz Stable, just temps are not justifiable. In a colder room maybe...
I expect I am restarting an old argument here.
My PD is not 100% prime stable on eight cores at 4.9GHz. It gets too warm. 4.6GHz is the prime stable frequency on eight cores.
However it is stable on prime using 4 workers at 55C core and 60C CPU. All cores are presumably at 4.9GHz, four are fully stressed calculating small FFT.
It is Aida64 stable at 51C and 58C on eight cores at 4.9GHz.
x264 HD benchmark v5.0.1 causes the most heat at 4.9GHz peaking at 66C but all tests complete.
Nothing that I do including x264 encoding, rendering, games benches etc. overheats the processor or causes lockups, instability, slow downs, black or blue screens at 4.9GHz.
Therefore I choose to run at 4.9GHz, 1.49V and bench at that frequency, it will also complete benches at 5GHz but at a higher voltage of 1.52V
4965 at 4.9GHz... I am testing it at 4.5GHz ;)!
What cooling are you using? Voltage is?
Greetings,
your blogger Fr4nc
Phanteks 1.49V
66c is that on the Cores of the CPU? if its on the Cores its fine 'just' if its the CPU its good.
The cores peak at 66C and drop back to 63-64C most of the bench, just the fan kicking up and cooling. Max CPU temp is 67C.
I am going to crossfire my 6950 for a bit to try and find the limitations of this processor.
Shocking game engine...
The CPU is very much the bottleneck in this game.
Nothing wrong with those temps.
Well you are only dealing with half the heat.
What clock you use for gaming depends how fussy you are about stability.
It has been my experience that abosulte stability on the 8 core PD's can only be proven up to around 4.6Ghz, higher than that and you cant sustain the high loads of programs such as P95 for long enough periods to be sure.
Temps go through the roof.
I used to be an absolute stickler for stabilty, with good reason though all my machines used there spare cycles to crunch prime number candidates.
I am a bit more flexible now and do on ocassion exceed max prime stable clocks for benches.
Never when gaming though, last thing i want is a CTD nanoseconds before i beat an end of level boss or finish a particularly difficult quest.
I am doing some lost planet 2 tests using the 680's and it appears i am CPU not GPU limited in SLI.
Going to test some more but i didn't expect that.
