New range of AMD FirePro now available to pre-order at OcUK!
20 Jul 2009
Midlands
OcUK now have AMD FirePro available for pre-order.
Check out the range below :)
AMD FirePro V3900 Professional Graphics Card - 1GB - DDR3 SDRAM @ £98.99 inc VAT
AMD FirePro™ V3900 professional graphics enables an exceptional user experience by delivering features and reliability designed to help boost the productivity of professionals working with low to moderate-complexity designs.
The AMD FirePro™ V3900 professional graphics card is powered by a new generation GPU, backed by 1GB of fast DDR3 memory, 480 stream processors and support for up to 5 (five) display devices using AMD Eyefinity multi-monitor technology and DisplayPort™ 1.2 multi-streaming technology.
Features:-
- Officially certified for superior reliability when working in many CAD and M&E applications
- Outstanding performance for projects ranging from low to moderate complexity
- Supports up to 5 simultaneous displays with AMD Eyefinity and DisplayPort™ 1.2 multi-streaming technologies1
- 1GB of high speed DDR3 memory (twice the capacity of other entry-level cards2)
- Massively parallel processing architecture featuring 480 next-gen AMD stream processors
- Support for both dual-link DVI and DisplayPort™ connectivity
- AMD AutoDetect technology automatically optimizes GPU driver settings as applications are launched
- Full OpenCL™, OpenGL and DirectX® 11 support (Please see www.amd.com/api for specific version support)
- PCI Express® 2.1 compliant
Specifications:-
- AMD FirePro V3900 Professional Graphics Card
- Core Clock Speed: 650MHz
- Stream Processors: 480
- Maximum GPU Power: 50W
- Frame Buffer / Memory: 1GB GDDR5 128 Bit
- Power Connectors: zero power connections
- Display Outputs: DL-DVI-I, DisplayPort x 1
- Warranty: 3 Years
Only £98.99 inc VAT.
ORDER NOW
AMD FirePro V4900 Professional Graphics Card - 1GB - GDDR5 SDRAM @ £134.99 inc VAT
AMD FirePro™ V4900 professional graphics offer strong performance and outstanding reliability while delivering features that help boost the productivity of professionals working with medium to large models, all in a single slot, half-length solution.
The AMD FirePro™ V4900 professional graphics card is powered by a new generation GPU, backed by 1GB of blazing-fast GDDR5 memory, 480 stream processors, and support for three simultaneous monitor outputs on a single card with AMD Eyefinity technology.
Features:-
- AMD Eyefinity Technology, With the revolutionary multi-display technology, the AMD FirePro V4900 professional graphics card supports three independent displays, delivering the most immersive graphics/computing experience with innovative display capabilities supporting massive desktop workspaces.
- DisplayPort 1.2, Support for the newest DisplayPort standard adds exciting new features such as high bit-rate audio, higher data bandwidth, and multi-streaming capabilities.
- AutoDetect Technology, As a user moves between applications, or opens new ones, the graphics driver settings are automatically configured for optimized performance.
- Full 30-bit Display Pipeline, Enables more color values than 24-bit products for more accurate color reproduction and superior visual fidelity.2
- Full Shader Model 5.0 Support, Helps create highly complex geometry and scenes without taxing the CPU.
- Certification, Ensure compatibility, reliability and the highest level of performance when used with professional 3D software packages.
- DirectX® 11 and OpenGL Advanced Features, Enables optimal performance in leading applications. Please visit www.amd.com/api to see specific OpenGL version support.
- OpenCL™, Industry standard API – Open, multiplatform development platform to help enable broad adoption of heterogeneous computing. Please visit www.amd.com/api to see specific OpenCL™ version support.3
Specifications:-
- AMD FirePro V4900 Professional Graphics Card
- Core Clock Speed: 800MHz
- Maximum GPU Power: 75W
- Frame Buffer / Memory: 1GB GDDR5 256 Bit
- Display Outputs: DL-DVI-I, DisplayPort x 2
- Warranty: 3 Years
Only £134.99 inc VAT.
ORDER NOW
AMD FirePro V5900 Professional Graphics Card - 2GB - GDDR5 SDRAM @ £349.99 inc VAT
The AMD FirePro V5900 professional graphics packs a huge punch in a single slot solution, making it the perfect solution for professionals working with a broad range of applications, moderately complex models and datasets, and advanced visual effects. The AMD FirePro V5900 features 2 GB of blazing-fast GDDR5 memory, 512 stream processors, and support for three simultaneous monitor outputs from a single AMD FirePro V5900 graphics card with AMD Eyefinity technology.
Features:-
- AMD Eyefinity Technology - With the revolutionary multi-display technology, the AMD FirePro V5900 supports three independent displays, delivering the most immersive graphics/computing experience with innovative display capabilities supporting massive desktop workspaces
- GeometryBoost Technology - Unleash your creativity with the new hardware architecture that provides ultra-high geometry performance and ensures smooth handling of complex models.
- AMD PowerTune Technology - State of the art power management technology that provides direct control over GPU power usage.
- DisplayPort 1.2 - Support for the newest DisplayPort standard adds exciting new features such as high bit-rate audio, higher data bandwidth, and multi-streaming capabilities.
- AutoDetect Technology - As a user moves between applications, or opens new ones, the graphics driver settings are automatically configured for optimized performance.
- Full 30-bit Display Pipeline - Enables more color values than 24-bit products for more accurate color reproduction and superior visual fidelity.
- Full Shader Model 5.0 Support - Helps create highly complex geometry and scenes without taxing the CPU.
- Certification - Ensure compatibility, reliability and the highest level of performance when used with professional 3D software packages.
- DirectX 11 and OpenGL 4.1 Advanced Features - Enables optimal performance in leading applications.
- OpenCL 1.1 - Industry standard API - Open, multiplatform development platform to help enable broad adoption of heterogeneous computing.
Specifications:-
- AMD FirePro V5900 Professional Graphics Card
- Core Clock Speed: 600MHz
- Stream Processors: 512
- Frame Buffer / Memory: 2GB GDDR5 256 Bit
- Power Connectors: 1x 6pin / zero power connections
- Warranty: 3 Years
Only £349.99 inc VAT.
ORDER NOW
AMD FirePro V7900 Professional Graphics Card - 2GB - GDDR5 SDRAM @ £584.99 inc VAT
The AMD FirePro V7900 professional graphics delivers incredible performance, superb visual quality, and outstanding multi-display capabilities all in a single-slot solution. It is an excellent solution for professionals who work with advanced visualization, complex models, and large data sets.
The AMD FirePro V7900 features incredible multi-display capability with AMD Eyefinity technology support for four simultaneous and independent monitors from a single graphics card. Also, the AMD FirePro V7900 is backed by ultra-fast GDDR5 memory and 1280 stream processors. •Unmatched workstation quality performance in the high-end segment
Features:-
- Supports four independent displays with AMD Eyefinity technology
- 2 GB of high speed GDDR5 memory
- Parallel processing architecture featuring 1280 stream processors
- Support for Framelock/Genlock
- GeometryBoost technology provides ultra-high geometry performance
- AMD PowerTune technology dynamically optimizes GPU power use
- AutoDetect Technology instinctively optimizes performance for multi-application workflow
- Optimized and certified for many CAD and DCC applications
- Full DirectX® 11 and OpenGL® 4.1 support
- OpenCL™ 1.1 support
- AMD CrossFire Pro Support
Specifications:-
- AMD ATI FirePro Professional graphics adapter - FirePRO V7900 - 2 GB
- PCI Express 2.1 x16
- ATI FirePRO V7900
- 2560x1600 @ 60Hz
- DirectX 11, OpenGL 4.1, Shader Model 5.0
- 2 GB - GDDR5 SDRAM
- 1280
- 256-bit
- 4 x DisplayPorts
- Max Monitors Supported: 4
- 3 years warranty
Only £584.99 inc VAT.
ORDER NOW
AMD FirePro W5000 Professional Graphics Card - 2GB - GDDR5 SDRAM @ £369.98 inc VAT
AMD FirePro W5000™ is the most powerful midrange workstation graphics card ever created, delivering significantly better performance than the competing card against a wide set of measurements.1 For example, it has the ability to process up to 1.65 billion triangles per second, allowing a designer to easily interact and render 3D models, while the competing solution is only able to process up to 0.41 billion triangles per second (up to 4 times less).2 In addition, with double the graphics memory (2GB vs 1GB of the competitor) and a memory bandwidth that is up to 2.5 times faster than the competitor, moderately complex models will be no match for the AMD FirePro™ W5000.3 It’s the ideal solution for professionals working with a broad range of applications, moderately complex models and datasets and advanced visual effects.
Features:-
- Drive up to four displays with AMD Eyefinity technology,4 enabling users to multitask across multiple applications with ease
- Offers unmatched application responsiveness, features double the memory and up to 2.5 times more memory bandwidth than the competing midrange solution3
- Support for DisplayPort 1.2, enabling resolutions well beyond standard HD and compatibility with multistream transport hubs that allow AMD FirePro™ W5000 to power up to six displays4
- Optimizations and certifications for many major CAD/CAE and media and entertainment applications
- Intelligent power saving and monitoring technologies for higher performance
- AMD Eyefinity Technology, Industry-leading multidisplay technology enabling highly immersive and unrivaled multitasking experience across up to four displays, powered by a single AMD FirePro™ W5000 graphics card.4
- GeometryBoost, Allows the GPU to process geometry data at a rate of twice per clock cycle resulting is a doubling in the rate of primitive and vertex processing. Triangle rates increase two-fold relative to a GPU that does not possess GeometryBoost.
- DisplayPort 1.2, Simultaneously output multiple, independent audio streams and display content at resolutions beyond standard HD (maximum resolution of 4096x2160).
- Energy Efficient Design, AMD PowerTune technology dynamically optimizes GPU power usage and AMD ZeroCore Power technology significantly reduces power consumption at idle.5
- AMD ZeroCore Power, AMD ZeroCore Power technology leverages AMD's leadership in notebook power efficiency to grant our desktop GPUs the ability to power down when your monitor is off, also known as the "long idle state."
- AMD PowerTune, AMD PowerTune is an intelligent system that performs real-time analysis of applications that utilize a GPU. In the event that an application is not making the most of the power available to the GPU, AMD PowerTune can improve that application's performance by raising the GPU's clock speed by up to 30 percent - automatically.
- Video Codec Engine (VCE), A multistream hardware H.264 HD encoder, for power efficient and quick video encoding.
Specifications:-
- AMD FirePro W5000 Professional Graphics Card
- Core Clock Speed: 825MHz
- Stream Processors: 768
- Warranty: 3 Years
Only £369.98 inc VAT.
ORDER NOW
AMD FirePro W7000 Professional Graphics Card - 4GB - GDDR5 SDRAM @ £649.99 inc VAT
AMD FirePro™ W7000 workstation graphics delivers incredible performance, superb visual quality and outstanding multidisplay design experiences to CAD/CAE professionals ? all from a single-slot solution. Its 3D primitive graphics performance is up to 2.1 times faster than the competing solution,1 giving designers smoother interactivity when working with complex 3D models and allows them to quickly visualize and render designs.
AMD FirePro™ W7000 offers up to 1.7 times more memory bandwidth than the competing solution, bringing the unmatched application responsiveness that professionals working with advanced visualization, complex models, large data sets and video footage need.
Features:-
- Drive up to four displays with AMD Eyefinity technology, and up to six utilizing DisplayPort 1.2 multistreaming technology,3 enabling users to multitask across multiple applications with ease
- Is more than five times faster than competing solution in single precision compute performance4 due in part to AMD’s all-new Graphics Core Next (GCN) architecture
- One of the industry’s first and only high-end workstation graphics cards to support DisplayPort 1.2, enabling display resolutions well beyond what competing solutions offer.5
- Optimizations and certifications for many major CAD/CAE and media & entertainment applications
- AMD Eyefinity Technology, Industry-leading multidisplay technology enabling highly immersive and unrivaled multitasking experience across up to four displays, powered by a single AMD FirePro™ W7000 graphics card.3
- Energy Efficient Design, AMD PowerTune technology dynamically optimizes GPU power usage and AMD ZeroCore Power technology significantly reduces power consumption at idle.6
- Framelock/Genlock, Ensures accurate and consistent video synchronization to external sources or multiple GPUs in different systems.7
Specifications:-
- AMD FirePro W7000 Professional Graphics Card
- Core Clock Speed: 950MHz
- Stream Processors: 1280
- Maximum GPU Power: 150W
- Frame Buffer / Memory: 4GB GDDR5 256 Bit
- Power Connectors: 2x 6pin / zero power connections
- Display Outputs: DisplayPort x 4
- Warranty: 3 Years
Only £649.99 inc VAT.
ORDER NOW
AMD FirePro W8000 Professional Graphics Card - 4GB - GDDR5 SDRAM @ £1,159.99 inc VAT
AMD FirePro™ W8000 is the high-end category leader for multitasking and application performance across up to four displays. It’s up to 4.5 times faster than the competing solution in single precision compute performance due in part to its innovative all-new Graphics Core Next (GCN) architecture. For 3D workloads, its GeometryBoost feature makes quick work of triangles, processing 1.8 billion per second, up to 1.5 times more than the competing product.
Equipped with a large 4GB GDDR5 frame buffer, W8000 delivers up to 1.5 times more memory bandwidth than the competing solution, and with high performance computing (HPC) features like error correcting code (ECC) memory and 806 GFLOPs of double precision floating point performance, it’s a great choice for HPC workflows.
Features:-
- Drive up to four displays with AMD Eyefinity technology,4 and up to six utilizing DisplayPort 1.2 multistreaming technology,4 enabling users to multitask across multiple applications with ease
- Operates at resolutions well beyond standard HD, at a max of 4096x2160, due to DisplayPort 1.2 support
- 3.23 TFLOPs of single precision compute performance for unrivaled application performance – up to 4.5 times more than the competing solution5
- AMD Eyefinity Technology, Industry-leading multidisplay technology enabling highly immersive and unrivaled multitasking experience across up to four displays, powered by a single AMD FirePro™ W8000 graphics card.4
- GeometryBoost, Allows the GPU to process geometry data at a rate of twice per clock cycle resulting in a doubling in the rate of primitive and vertex processing. Triangle rates increase two-fold relative to a GPU that does not possess GeometryBoost.
- Partially Resident Textures (PRT), PRT can utilize absolutely enormous texture files, up to 32 terabytes large, with minimal performance impact. PRT accomplishes this by streaming small bits of these massive textures into the GPU as needed, giving compatible applications a virtually endless supply of unique texture data.
- Error Correcting Code (ECC) Memory, Helps ensure the accuracy of your computations by correcting single or double bit errors as a result of naturally occurring background radiation.
- DisplayPort 1.2, Simultaneously output multiple, independent audio streams and display content at resolutions beyond standard HD (maximum resolution of 4096x2304).
- AMD ZeroCore, AMD ZeroCore Power technology leverages AMD's leadership in notebook power efficiency to grant our desktop GPUs the ability to power down when your monitor is off, also known as the "long idle state."
- Framelock/Genlock, Facilitates synchronization to external sources (Genlock) or synchronizes 3D rendering across multiple GPUs in different systems.7
Specifications:-
- AMD FirePro W8000 Professional Graphics Card
- Core Clock Speed: 900MHz
- Stream Processors: 1792
- Maximum GPU Power: 189W
- Warranty: 3 Years
Only £1,159.99 inc VAT.
ORDER NOW
AMD FirePro W9000 Professional Graphics Card - 6GB - GDDR5 SDRAM @ £2,799.98 inc VAT
The AMD FirePro™ W9000 is the industry’s most powerful professional graphics card available for CAD/CAE and Media & Entertainment professionals. It’s up to 3.9 times faster than competitive solutions in single precision compute performance, due in part to its innovative all-new Graphics Core Next (GCN) architecture that allows it to effortlessly process challenging compute workloads. In addition, the 3D primitive graphics performance is up to 1.5 times faster than equivalent competitive offerings, delivering better interactivity when working with complex models and faster render times.
Equipped with a massive 6GB GDDR5 frame buffer, W9000 delivers up to 1.8 times more memory bandwidth than competitive solutions3. With high performance computing (HPC) features like error correcting code (ECC) memory it’s the ideal choice for HPC workflows. Its six mini DisplayPort outputs can drive up to six independent displays at a resolution 12X standard HD using AMD Eyefinity multi-display technology allowing designers unparalleled productivity and flexibility.
Features:-
- Cutting-edge graphics and compute performance through the all-new Graphics Core Next (GCN) architecture, delivering up to 1.95 billion triangles/second and 4.0 TFLOPs of single precision compute performance for unrivaled performance in your workflow
- Error correcting code (ECC) memory to ensure precision and accuracy in your results
- Drive up to six displays with AMD Eyefinity technology, allowing users to multi-task across multiple applications with ease
- Optimizations and certifications for many major CAD/CAE and Media & Entertainment applications
- AMD Eyefinity Technology, Industry-leading multi-display technology enabling highly immersive and unrivaled multi-tasking experience across up to six displays, powered by a single AMD FirePro™ W9000 graphics card.
- AMD ZeroCore, AMD ZeroCore Power Technology leverages AMD's leadership in notebook power efficiency to grant our desktop GPUs the ability to power down when your monitor is off, also known as the "long idle state."
- AMD PowerTune, AMD PowerTune is an intelligent system that performs real-time analysis of applications that utilize a GPU. In the event that an application is not making the most of the power available to the GPU, AMD PowerTune can improve that application's performance by raising the GPU's clock speed by up to 30% - automatically.
- Framelock/Genlock, Facilitates synchronization to external sources (Genlock) or synchronizes 3D rendering across multiple GPUs in different systems (Framelock).
- Video Codec Engine (VCE), A multi-stream hardware H.264 HD encoder, for power efficient and quick video encoding.
Specifications:-
- AMD FirePro W9000 Professional Graphics Card
- Core Clock Speed: 975MHz
- Stream Processors: 2048
- Maximum GPU Power: 274W
- Frame Buffer / Memory: 6GB GDDR5 384 Bit
- Power Connectors: 2x 8pin / zero power connections
- Display Outputs: DisplayPort x 6
- Warranty: 3 Years
Only £2,799.98 inc VAT.
ORDER NOW
These cards can game but they will be slower than the same GPU based on the HD series for instance. The silicon is binned to be the best for these cards however the extra expense comes from the cost of drivers, support and the additional features and ram.
Worth it if used for the correct application. :)
