- 11 Mar 2008
This will be used for software development and database work, as well as some gaming when time allows, but want to check a few things before I take the plunge. I'm intending to overclock, though nothing extreme maybe somewhere between 4 and 4.5GHz
My basket is as follows:
YOUR BASKET
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £259.99
1 x Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games £239.99
1 x Samsung 256GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD256BW) £209.99
1 x Crucial RealSSD M4 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT256M4SSD2) £164.99
1 x MSI Z77A-GD65 Intel Z77 (Socket 1155) DDR3 Motherboard £131.99
1 x Toshiba (7K3000.D) 3TB SATA 6GB/s 64MB Cache - OEM (DT01ACA300) £98.99
1 x Corsair Builder Series CX 750w Modular '80 Plus Bronze' Power Supply (CP-9020061-UK) £69.98
1 x Patriot Intel Extreme Masters 16GB (2x8GB) DDR3 PC3-14900C10 1866MHz Dual Channel Kit (PVI316G186C0K) £59.99
1 x Antec Kúhler H2O 620 CPU Watercooler (Socket Intel LGA 775 / 1155 / 1156 / 1366 / AMD AM2 / AM3 / AM2+ / AM3+) £55.98
1 x Pioneer BDC-207DBK 8x BluRay ROM / DVDRW SATA-II Optical Drive - Black (OEM) £54.98
1 x BitFenix Shinobi USB3.0 Gaming Case - White/Black £49.99
Total : £1,413.36 (includes shipping : £13.75).
1. Will the BitFenix Shinobi case be big enough to to take this? - main items that I guess could cause a problem are the 7950 card and maybe the watercooler.
2. Is the Patriot Extreme memory reliable? (Opted for 1866MHz to help with overclocking, priced very close to1600Mhz anyway) This stuff is at a good price, and is blue (trying to keep the colour scheme
3. I'm sure the PSU will power this, but will it be able to support a second 7950 if I add another in the future?
The 840 Pro will be the boot drive (OS and main Apps), with the M4 used for storing some games (the rest going on the 3TB HDD). I don't want to go for RAID as I'm too worried about possible array failure.
Watercooler was chosen to ensure the memory slots have space, will be going to 32GB in the future
I chose an i7 over the i5 since I'll be doing development and database work, the extra threading capability will be useful there.
The motherboard was chosen as it has at least 4 6GB/s SATA ports and plenty of USB3 ports. Had also considered the Gigabyte UD5H, but this one seems to offer what I need and costs less.
Is there anything I'm missing or haven't considered?
YOUR BASKET
)3. I'm sure the PSU will power this, but will it be able to support a second 7950 if I add another in the future?
The Shinobi can take upto 320mm long GPUs so it can take that 7950 no probs, I used the windowed version as although it's £10 more it does have the window and comes with two 120mm fans not just the one in the version you used.
The 'core' model has a windowed one if white, but it doesn't have any fans or the mesh strips on it, so probably as well just adding extra fans to my order.
