YES THAT MIGHT WORK, plus the speakers already have an internal amp
http://www.overclockers.co.uk/showproduct.php?prodid=SP-004-ER&groupid=702&catid=22&subcat=719
or is this PC only......i also have a Denon DVD player so i might be able to connect via here
• 1 CI (Common Interface)
• 3 HDMI (side) / Audio Return Channel (Input 2)
• 1 SD Card slot
• 2 USB port
• 1 Composite Video Input shared with Component: AV2: CVBS w/Cable adaptor (lower)
• 1 Audio Input (for HDMI, Composite, Component) RCA phono type w/Cable adaptor x 1 (lower)
• 1 Component Video Input shared with Composite RCA phono type w/Cable adaptor x 1 (lower)
• 1 LAN Port
• 1 Analogue Audio Out: RCA phono type w/Cable adaptor (bottom)
• 1 Digital Audio Output (Optical) (lower)
• 1 Headphone Jack (bottom)
• 1 Service Port
• 1 21-Pin Input/Output AV1: AV In/Out, RGB In, Q-Link w/Cable adaptor (lower)
