ideas for a gaming pc please
Change out the 7750 as it's running 1600MHZ effective as opposed to the 4800MHZ it's meant to because MSI have decided to cripple it and release the SKU.
Yes my friend, i not really look into things before i got that pc.
I should have come on here 1st. Cheers for the help.
Would that build play most moden games?
Whoops, didn't realise it was using GDDR3 instead of GDDR5, explains why it had 2gb of vRAM though :P. Fixed.
At the moment i dont play high end games but would need the build to be able to play generals 2 at decent sttings, it comes out later this year.
the pc would mainly be for that game.
Yes i would like an os, windows 7 is fine.
If this build would play that at decent settings then im happy, any input would be good as im not that sure about building a pc, so need as much help as i can get.
ok thank you for the information.
im happy to go with this build, but a few have said no to the gpu.
what would be the best gpu for this build?, i could upgrade the psu if needed to as id save alittle going with windows 7.
cheers all, this site is being a big help.
