I'm unable to use msi afterburners fps limiter and fraps at the same time. Games just won't load if i have them running at the same time, so i need an alternative.
I'm trying to run and record some benchmarks capturing frame times. I want to capture the times with vsync on and off, plus with vsync on and an fps limit slightly below vsync.
So far ive tried RadeonPro to limit fps to 58, didn't work. Instead it kept the fps at 60. FPS Limiter 0.2, didn't work. Other than those two i can't find anything. Any suggestions?
