Hi,
I'm planning on using some of my old system components to build a lounge HTPC/casual gaming machine. Specifically, I plan on playing console-ish (controller friendly) games like Assassins creed, Batman AA, Just Cause etc. I'll be playing the games at 1080p, and I'm not a massive quality whore. If I can play games at a smooth 60 FPS at reasonable settings, I'm happy.
The CPU in the proposed system is an Intel E8400 @ 3.6 GHz, 4 GB of DDR2 RAM, a Corsair builder series 430 Watt PSU and a Vertex 2E SSD.
So, will a GTX 650ti be able to meet my needs, or am I going to have to spend a little more to be confident? My worry with going for a GTX 660 is the power consumption - will a 430 Watt PSU still be OK?
Before you ask, I'm not dead against AMD cards or anything. It's just that I've had lots of AMD cards in the past, and since my last card purchase (560 ti), I've had far fewer driver/performance issues. Therefore I'm tempted to stick with Nvidia for the moment.
