- 15 Feb 2011
- Slough
I'm having a discussion on another forum about coolers. this is what he has said so far:
can someone explain who is right in this discussion and why please, because i have zero experience with closed loop water cooling
A lot of the time people say their huge tower cooler gets lower temps is because their huge tower cooler is either on a bench case or they haven't run the computer for hours. Air cooled heatsinks build up in temperature over the more time you run it unless your fan is capable of dispelling more heat then your processor is putting into the tower, and that would require fans like kazes, deltas, and vantecs, which are incredibly loud.
Reaper 392 said:Admittedly i havent tested this myself, but surely the same can be said for water coolers? its a simple case of you're putting (heat) energy in, its chucking that energy to the surroundings. It doesnt mater if the transfer method of processor to air is big slab of metal or some water and a small slab of metal mounted elsewhere. it just depends on how much heat the cooler can get rid of.
From reviews that i've seen, the only all in one water cooler that can outdo tower coolers is the H100. everything else can be beaten by a big tower like the Noctua NH-D14 or the thermalright silver arrow to name a couple
No, because a water block carries the heat down the pipes to the radiator, which means the maximum amount of heat that is inside the coolant is much less then the potential heat of a tower cooler. A tower cooler will get hotter and hotter over time without loud, big fans, but a closed loop system will have much longer temperature stability.
A lot of these reviews are benching their towers open air and most do not do something like a 24-48 hour prime92 run, while they mount the closed loops inside the case, and usually use the stock closed loop fans, which although okay are usually not as good as higher grade fans.
