Recently purchased 2x VTX3D 7970's... currently running at 1050/1425
with -
3820 @ 4~ghz
16gb ram, 2x HDD's etc etc !
...Off a 750w "competitors" PSU (Roughly £60?... fairly bog-standard)
The system runs fine as it is, run multiple benchmarks etc.
But, how far would you OC the GPU's?! Air-flow isn't an issue.
Basically, will the PSU be able to cope with a significant OC? and, if not... what happens?! If the PSU can't hack it, will it just cut out or, blow up?!
Thanks!
with -
3820 @ 4~ghz
Thanks!
