Freezing at random times
3 May 2012
Far away
Well i'm having a problem since i have upgraded to Windows 8, It happens mainly whilst i'm playing League of Legends. All the happens is a loud 'DURRR' noise and get a blue screen saying 'Your computer has encountered a problem', This causes the computer to freeze and i have to give it a reboot for it to work. What's the best way to work out the problem?
Check your event logs I would guess, also what error code is displayed when it blue screens?
Are you overclocked?
I'm not sure on the code, Will check next time it does it. i'm normally just annoyed so just reboot straight away haha! will pay more attention next time!.
Yes i am overclocked!
Check the error logs or take note of the code next time but if I was you I'd be looking at the overclock primarily.
I will take note of the code and check the log too, Just need to get to the bottom of it now as it's bugging me!.
Hmm the overclock was fine on windows 7 and it's only started doing this since i upgraded to windows 8 though.
Just got home and looking at the event viewer, This 'Critical' error seems to have popped up a lot, Doesn't mean much to me does it to any of you guys?
http://forums.overclockers.co.uk/announcement.php?f=129
download and use these tools as it seems to be only happening at max ie in games
if this also makes it happen the same, then overclock or memory could be the error
it helped me, but i guess you have already tried it and im being to basic, but it may help others to see and not have done it / tried it
good luck
Running the tests now and at idle it's at 2200mhz and when running prime 95 it's 2589mhz so the clock is working at max and still haven't encountered an error as of yet
CASE: Cooler Master Elite 310 Mid Tower Gaming Case with see-thru side panel
POWERSUPPLY: OCZ ZS Series 650W '80 Plus Bronze' Power Supply
MOTHERBOARD: Asus P5QL Pro P43 Chipset LGA775 FSB1600 DDR2/1066/800 Main board
CPU: Intel® Core™2 Quad Processor Q8200 (4M Cache, 2.33 GHz, 1333 MHz FSB)
HDD: 2GB Samsung Spin point F3 SATA-II 3.0 GB/s 16M Cache 7200RPM Hard Drive
RAM: 4GB 4 x 1GB PC6400 DDR2/800 Dual Channel Memory
DVD DRIVE: Sony Optiarc 22X DVD±R/±RW + CD-R/RW DRIVE DUAL LAYER Black
GRAPHICS: MSI GeForce GTX 560 1024MB GDDR5 PCI-Express Graphics Card
SCREEN: Samsung SM943NW 19" 5MS 1440x900 DVI LCD Wide Monitor
on that board try one/two clciks more cpu northbridge voltage from what auto is using,and one/two clicks more dram voltage
