Build Spec Request
6 Jan 2013
Rollergirl
I've never built a system before, and I want to take one on as a project. I would be grateful if you guys could help me out with a spec. I've seen a step by step guide in this section on how to do it, so I'll follow that and only ask build questions here when I am unsure.
I don't want to set a monetary budget. Instead, I want to aim for a particular system. I want a gaming system capable of running Skyrim on full graphics. I would like to leave some scope for future upgrade, ie faster graphics card, more ram etc. But initially a system that will cope with that game will be fine. Obviously, the cheaper the better but I wouldn't want to compromise too much on price if it's a big drain on performance.
There is no requirement for optical drive, although I may fit one in future. I do require wifi adapter and Ethernet port. There is no requirement for a sound card, but again I would like ability to install one in future. I don't need card readers and the like, but I would obviously need some USB ports, preferably USB 3.0.
Is this enough info to go on?
** edit - budget set at £1500 **
Currently Purchased
YOUR BASKET
1 x Corsair Professional Series HX+ 850W '80+ Gold' Modular Power Supply (CP-9020032-UK) £129.95
1 x Cooler Master CM-690 II Advanced USB3.0 Dominator Case - Black £85.99
Total : £230.04 (includes shipping : £11.75).
SLI / Crossfire allows you to run dual graphics cards for that extra performance in games.
SLI is dual Nvidia cards and Crossfire is for AMD (ATI) cards.
xfire/sli is using two graphic cards together. So as your current one gets old, you buy the same model and stick it in, tag team.
sli = nvidia cards
xfire = amd cards
Being new to this I have to ask, what do you mean by xfire/sli? Also, three slightly different specs here, does one have a particular advantage over the other?
You can add a second graphics card to the system, so for example if you bought a 7950 card you could buy a 2nd one to boost performance.
First of all, thanks for being patient with the tedious newbie questions... got to get started somehow!
I don't want to xfire straight off as I need to keep the cost down, however I would like to have the option in the future. Does that change anything?
If you want x-fire your looking at around an extra £60-70 for the motherboard and PSU change.
For a single GPU setup +1 for RJC's spec, never fond of Saphire because of the customer support and warrantiy side.
You will need to increase PSU and change the motherboard to one which can do dual 8x ports.
Ok, I think I need to allow for future xfire if the additional cost is only £60. It seems a small additional cost as I imagine 2 cards would be a serious boost in future.
You all seem to have allowed for SSD as well as DDR. Again it's a newbie question but I'm thinking the system doesn't need SSD so why do we have it?
It might not 'need' an SSD but you will definitely see the performance gain in it. It's worth noting that there is no gain whilst gaming, but boot up times will be amazingly lower and the system will be more responsive. Also, SSD's performance don't deteriorate over time, unlike HDD's.
I use the SSD for Windows install and most common used programs, I will not go back to a mechanical hard drive for windows.
You need DDR3 ram for the system to work.
SSD's can drastically reduce loading times of anything you have loaded onto it. The primary being the OS then with any programs you want. I know some people who have large SATA 2 SSD's for all their steam games.
I think but don't point and yell if im incorrect ;) That a decent 650W can actually x-fire those cards.
This PSU here:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-017-SS&groupid=701&catid=123&subcat=2383
I have yet to be proved wrong, but also yet to see someone who has done this :)
Interesting regarding the SSD. I assume the SSD shows as first drive C: and the mechanical drive shows as a storage drive D:
This takes me to another question, the OS. What are the options with installing Windows. For example could I install on a mechanical drive initially, and then format that drive and install the OS on a later installed SSD? And, would you recommend Windows 7 or 8. I use 8 on another pc just now and I don't mind it, but are there any issues with game compatibility or driver compatibility?
The SSD will show up as a normal drive and as drive C and the mechanical as the next drive letter.
I use Win 8 for gaming and not come across any issues, but the choice is yours really :), but I would go with a SSD now and install the Operating System on that. All you need todo is enable ACHI in the BIOS before installing windows.
