Sadly, I agree ArcNvidia have something that can seriously make games look so much better with all those nice particle effects but just don't push this technology enough.
They would sell more Nvidia cards if every other game had these effects in them.
weehamish said:snip
No rusty u cant run BL2 above low if you dont had an Nvidia card as its greyed out, my bro has a 580 and i had a 660.
My point is why does the 660 struggle with it on max with the Q9450 when the 580 is fine with the i7?
Im sure the 660 and 580 are nearly the same with some OC on the 660?
Im sure it could be done by AMD but Nvidia wouldnt let them as they put loads money into it?
From what I recall Weehamish you can alter a .ini to allow it to run on your CPU.
I've ran hardware accelerated PhysX on older CPU's in Mafia 2 and Batman AA, but as far as I remember they were using archaic code.
And with BL2, you always get hit and miss information, "Yeah it's running fine PhysX maxed out on my CPU", "No it's running like rubbish".
Pretty much the same lark you get when people say they're running X game with Y hardware at 60FPS maxed out perfectly fine, then you try it yourself with the same hardware and go "Lulwut".
580 and an i7 would be better than a 660 and a Q9450 too, moot point.
I know the i7 system is better but the 660 and 580 are not much different, the 580 was the top card while the 660 is the low-med but when oced it produces similar results to the 580.
So are you saying the 580 can handle physx better? Even though the 660 is newer?
My borderlands 2 never once let me go above low on the 7850 or 7970 so i dunno how you could?
Well lets hope 3.0 is good![]()
Lol rusty, i just checked mine and i can enable high now also :\ it was defo patched in as it wasnt there before.
I have not changed ini file its defo patched in.
Now i know why i confused you rusty sorry i didnt make it clear, but yeah it was greyed out when it was first released.
Seems like a common problem some peoples was greyed others was not, go google it its everywhere.
