Today Only Items!
Prices end tomorrow 9am or until deal stock runs out!
Corsair Carbide 500R Midi Tower Case - Black @ £89.99 inc VAT
Want even more outrageous cooling flexibility? Step up to the 500R. It adds a 200mm fan mounted on the side panel’s mesh screen for extra GPU cooling, a multi-channel fan controller, and removable and relocateable hard drive cages. The ability to move and remove hard drive cages not only improves airflow — it also allows you to install graphics cards of up to 452mm in length.
Support for USB 3.0 and 2.5” SSDs is built-in. Two USB 3.0 connectors are provided on the front panel and connect directly to motherboards with compatible USB 3.0 headers. Integrated SSD support lets you install 2.5” solid-state drives in any of the hard drive bays, without having to deal with adapters.
The beauty on the inside goes beyond the black-painted interior. Corsair’s innovative cable management system provides a straightforward way to route cables behind the motherboard, not across it where it can interfere with airflow and give your system a cluttered look. And since looks are an important part of any build, you’ll appreciate the ability to turn the front panel fan white LEDs on or off with the push of a button.
- Side panel with mesh fan mount locations
- Dimensions: 20.5” x 8.1” x 20”
- Four 5.25” drive bays
- Six 3.5” hard drive bays with 2.5” compatibility
- Eight expansion slots
- Supports most 240mm dual radiators (15mm spacing)
- Six 120mm/140mm fan mounts
- Four 120mm fan mounts
- Front I/O Ports: 2 x USB3.0, 1 x FireWire, 2 x Audio
- Two-year warranty
Only £89.99 inc VAT.
ORDER NOW
Surge Protected Power Centre with 8 Socket/LAN Port/Telecom/Modem/Broadband Protection - 2 Metre @ £14.99 inc VAT
Fellow gamers and enthusiasts know of the heartache when your precious computer is out of action. So why not do all that you can to prevent outtages due to damaged hardware. Well now for an amazingly low price you can have the peace of mind that you are protected against electricial surges and spikes.
Hundreds of power surges can occur in your home or office everyday. The switching on and off of lights and household appliabces like refridgerators, washin machine and tuimble dryers can cause surges. Most warranties do not cover power surge damage, and these surges and spikes can cause serious damage to your electronic hardware. Even low energy surges and spikes can cause gradual component degradation leading to hardware failure. The manufacturer MasterPlug are that confident in their technology that this MasterPlug product comes with a 'connected equipment warranty'. In the unlikely event that a surge passes through this device and any damage occurs to your hardware, MasterPlug will pay up to £3000 for the replacement equipment*.
- Surge protection for your home office and PC equipment: computers, fax machines, scanners, routers, from damaging surges and spikes.
- 8 Surge protected power sockets with three channel protection & safety thermal cut-out
- Power & surge neon indicators. LAN/Ethernet Surge protection. All necessary leads supplied.
- Telecom/Modem/Broadband connection surge protection with telecom splitter provides protection for two devices from one input.
- £3,000 connected equipment 3 year warranty for peace of mind*.
* Subject to warranty registration online at the time of purchase.
Only £14.99 inc VAT.
ORDER NOW
- Two-year warranty
ORDER NOW
ORDER NOW
