**ASUS ARES2 AVAILABLE FIRST FROM OcUK (NOW IN STOCK)!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK shall be the first and potentially the exclusive retailor for Asus Ares 2 crazy mental expensive graphics card. If you want the fastest card there is, well this is it:-
Asus HD 7990 ARES 2 6144MB GDDR5 PCI-Express Graphics Card @ £1,199.99 inc VAT
Continuing on the success of its popular ROG ARES/MARS series graphics cards. ASUS ROG today presents the fastest and most powerful graphics card currently available in the form of the limited edition ARES II.
Factory overclocked Dual HD 7970 GPUs running @1100MHz and 6GB GDDR5 running @ 6600MHz makes ASUS ROG ARES2-6GD5 the Performance King by 13% faster than GTX690 and 134% faster than generic HD7970.
Extra-efficient heat dissipation handled by a new hybrid thermal design that includes air and liquid cooling. ARES II employs exclusive ASUS DIGI+ VRM and 20 phase Super Alloy Power technologies for greater stability and product longevity. The bundled ROG Edition GPU Tweak utility gives customers direct access to graphics card overclocking and tuning, tapping its power via a user-friendly interface.
Each ASUS ROG MARS II carries a unique metal suitcase and aluminum serial number plate which is individually laser carved and sequentially numbered to certify the limited edition status, making it a collector's item
Features:-
- Fastest dual GPU graphics card on the planet
- Hugely overclockable
- 30c Cooler due to hybrid H20 cooling solution
- Limited edition (1000 units worldwide) with Unique metal case
- Performance King - 13% faster than GTX 690!
- Acclaimed DIGI+ VRM with 20 Phase power
- HD 7970 GHz x2
- 28nm GPU
- PCIE 3.0
Specification:-
- 2x 7970 GHz Cores
- 1050MHz Base Clock per core
- 1100MHz Boost Clock per core
- 6600MHz GDDR5 Memory speed
- 6144MB GDDR5 Memory
- Memory Interface 768-Bit
- Connections: 1x DVI-I, 1x DVI-D, 4x DisplayPort
- Power Connections: 3x 8-Pin connectors
- Stream Processors: 64 CU / 4096 ALU
- Texture Units: 256
- ROPS / Z-Stencil: 64 / 256
- Load / Idle Board Power: <600W / <3W
- 3yr Warranty
Only £1,199.99 inc VAT.
ORDER NOW
That price.....I think people are gona have to sell their kidneys to get this.
Also the 8000 is coming out so yeh....they are abit late with this.
cool pic shows 2 of them on the silent pro gold supply I've got and a likely way to position the 2 coolers. I have nowhere to put an extra cooler myself though else half my girlfriends bonus would be going on 2 of these cards for us :P
I'd love to see the temps on this, single thick 120mm rad cooling two tahiti cores at 1100mhz, my gut instinct tells me it's going to get very very hot.
