I`d personally get 3570k, but if you want AMD.. 8320 isnt far behind...
as far as gamings concerned id say the 8320 is still way off the I5?
3570k is still better... but gap is small... we are talking 3-5 fps.
I see yet again nobody has asked the opening poster if he intends to overclock.
Fairly important question in any spec me thread really.
I do not intend to overclock, maybe later in the future. Another thing that I have come across, is that most motherboards come with SLI. I am going to use only 1 graphics card. I do not need more slots. Last mobo I had was an EVGA 780 or 680 i cant really remember, and it had 3-way SLI which I never used. What do you suggest I should buy?
I found this one but I dont know about performance
http://www.overclockers.co.uk/showproduct.php?prodid=MB-501-AS&groupid=701&catid=1903&subcat=2046
You could go with an FX6300/8350 chip if you want AMD or i5 3570k if Intel.
FFS another intel fan boy spam.
Why has every 1 just gone intel are better for gaming?
The Op hasn't once said he even plays games?
He might render all day long then AMD will wipe the floor with a 3570K and match a
3770K.
23 posts later and I have seen 2 posts that are actually helpful.
Op what do you plan on using the system for? Rendering? encoding? Gaming?
