Dell XPS 420 cheap upgrades
28 May 2012
I've seen some threads in the past where people have upgraded their XPS 420. Personally I'm still pretty happy with a pc that my mate got brand new for around 400 quid.
Original components:
2 Samsung HDDs. My hard disk sentinel program is telling me one of them is about to fail but then it says its fine after a while...happens most days.
Quad Core Q6600
Geforce 8800GT
Motherboard
PSU 375W
Case (obviously)
Stuff I've added:
Two 22" acer monitors
8GB Crucial Ballistix Ram (initially bought 4 sticks of tracer but first 2 died within 2 years and the other 2 have just gone so crucial are replacing the dead ones and the ones I got as a replacement for 4 new sticks of Ballistix sport)
Hitachi 1TB hard drive
2 x 80mm fans (one of which isn't powered as I ran out of connectors)
2 exhaust fans, both screwed into my expansion bays at the rear to suck out heat
1 hard drive cooling fan which sits in the drive bay below the original DVD drive. I use it to cool my 1TB disk but also to get extra into the system
What I'm looking at getting:
The game I play most is Football Manager 2013 and I rarely play 3D intensive games. Aside from playing that the only other things I do is internet, watch films and trade forex (hence two monitors).
The only issue I have with my GFX card is how hot it gets when I run skyrim but admittedly I only realised it had a fan when I played this game. But like I said, I rarely play 3D games anyway.
Motherboard + RAM
From what I've read, people are recommending the Asus striker 2 motherboard / 780i / 790i motherboards.
Having done some research, the only viable way of getting it without spending a fortune is ebay. As I write this, one board is bidding at 51 quid, the other at 69.
Personally I don't see the point of paying that much if I'm not a heavy 3D gamer.
I was thinking of a DDR 3 mobo like the ones above but for a lot less money. My initial research has thrown up this:
ASRock G41M-S3
Seems to be a solid mobo for £35 and I'm pretty sure the parts I've got in my system at the moment will fit that?
In terms of ram, even though I'm getting sent some replacements sticks of DDR2, buying 8GB of DDR3 will surely provide a massive performance jump? The mobo does support 8GB and I do do a lot of multitasking as I usually have football manager running as well as my Mt4 platform for trading as well as Chrome with lots of tabs open
The official specs says the mobo "Supports DDR3 1333(OC)/1066/800 non-ECC, un-buffered memory". Does this mean that you can put 1333 memory in there and then over clock it or that it only supports up to 1333 max if overclocking slower ram (I'm thinking the former rather than the latter).
I'm looking at an 8GB kit (2x4GB) of 1333 memory. I'll be honest, having received such amazing and fast customer support from crucial, I'd be reluctant to try anyone else. I'm thinking of going with:
Crucial 8GB (2 x 4GB) Ballistix Sport DDR3 1333MHz CL9 1.5v 240pin
I've found it selling for £32 including delivery.
In my head I want 8GB of RAM because I think I need it. But, I'm coming from using DDR2 so having 4GB might be more than enough for what I currently need.....you guys will help me on that!
However it seems that for only a little more money I can double up to 8GB so for an extra 7 - 8 quid it might just be better to get more....?
Case
My current case, as most of what I have read about my machine has stated, isn't the best for heat dissipation, hence the numerous fan additions (makes a bit of difference but not massive). I want a case that has good ventilation and cheap. Not bothered about looks.
If basing the case on the mobo above then I need a micro atx one.
Coolermaster Elite 342 Black Micro ATX Case
That should do the trick and I can get it for about £27 on ebay brand new. It also comes with a 120mm fan which is good. Also allows for me to put my two 80mm fans in and also I think I can put the exhaust fans in the expansion slots at the back.
I've got my original dvd drive but I could possibly do with putting another drive in to copy cds and dvds. This isn't essential though. More concerned with everything else.
PSU
TESLA QUIET EDITION 500W ATX COMPUTER POWER SUPPLY UNIT
Has gotten solid reviews and I can get it for around £15 quid on ebay.
Total cost:
MOTHERBOARD - £35
8GB RAM - £32
CASE - £27
PSU - £15
Have a look guys, see what you think. I certainly don't wanna be spending anything more than 100 quid really. Any suggestions are welcomed!
Cheers!
£100 pounds, spent more on 1 hard drive and you seem to like somewhere else, so can't say i'll quote or spec anything tbh, sorry.
strange first post, are you certain you posted on the right forum?
You are really pushing it, not sure you'll get what your after:
You cannot skimp on the PSU, it's on of the most important parts. You get a bad quality PSU and you loose all your components. If you can stretch to £140/150, you can go with trinity which has proven to run the likes of BF3/FC2/Skyrim, but your looking at the Quad core black edition, not the cheap A4 version. If you can push to £200, you can get the Black Edition (£95) which would give you better graphics over the A4.
That would do what you want!
i think snips86x he will buy from somewhere else tbh
im sure the rules say also not to mention competitors names etc like feabay etc
think your post may get either edited or binned
sorry
sorry
Instead of having a go and increasing your post count, maybe try helping him?
The Q6600 you have should be ok, I personally would be looking at a quality PSU like snips mentioned and picking up a second hand GTX 460.
sorry
Why would my post get removed!!! nothing there about competitors!!!!!
Option 2:
not yours snips86x,sorry you misunderstood me
MORE SPEED you seem to be bothered more than i about post counts, i couldn't care less and have done nothing but help here.
just didn't want someones first post to be there last
competitors!!!!!
etc etc etc
but hay ho, what ever.
Well I guess its a start. Didn't realise I opened a can of worms with my first post so apologies for that.
Like I said I just want to just give an injection of speed into my machine. I appreciate your suggestions guys. I'll keep refining my options!
Cheers
Option 2:
This option looks pretty good. One question I have though is does that mobo support that RAM? It says "Supports DDR3 1333(OC)" so not sure?
Other than that, plus a case, I think that's a reasonable way to boost my PC for my needs.
