Cheap suit which doesn't look like crap.
23 Dec 2010
Hey guys,
I'm on the lookout for a suit, budget of around £75-£100, can anyone help me find one?
I've looked around but they all seem a bit rubbish, well according to the customer reviews.
I'm a fairly large lad, waist of around 42" would do me fine.
Thanks
Please go for the Winston Churchill look with the bowler hat aswell... it would look awesome !
also carry a quart of whiskey with you aswell....
You will sometimes find reasonable suits on the rails at TK maxx for around £80-100. You'll need it altered I'd imagine but that will be the case with most of the places you will be visiting.
Go to one of the high street retailers and make sure it's a high wool mix and is simple. Now's a good time to look with the sales on but you need to ideally try them on as every place have different cutting so will one suit some more than others.
Yup also like the recent M&S ranges. Next outlets have some cheaper 'SP' range if you are near one, also Jeff Banks outlets have some smart stuff.
If you can get to a Slaters they have suits from around that sort of price and offer free alterations.
Even a cheap suit can look half decent if you've had it well altered to fit.
