10 Jan 2013 at 14:18 #1 isonomicjedi isonomicjedi Associate Joined 30 Dec 2012 Posts 1,153 Location midlands Looks like I got nice temperatures in idle What should I look out for.
10 Jan 2013 at 14:30 #2 chrisoverson chrisoverson Associate Joined 16 Nov 2012 Posts 252 Is that at 4.2 ghz? Not bad if so. Also, what temperatures do you get on full load (Prime95 for example), and what cooler are you using please?
10 Jan 2013 at 14:33 #3 BluSky BluSky Associate Joined 15 Nov 2011 Posts 1,237 chrisoverson said: Is that at 4.2 ghz? Not bad if so. Also, what temperatures do you get on full load (Prime95 for example), and what cooler are you using please? Click to expand... From his signature he is using the zero infinity phantom cooler (seen here: http://www.overclockers.co.uk/showproduct.php?prodid=HS-000-ZE)
10 Jan 2013 at 14:48 #4 isonomicjedi isonomicjedi Associate OP Joined 30 Dec 2012 Posts 1,153 Location midlands I just prime for a minute or two to check the overclock but will give a full test later when I've downloaded my files from cloud so I can work. Yes it is the Zero Infinity Phantom Cooler
10 Jan 2013 at 14:50 #5 Mei Mei Soldato Joined 3 Jan 2012 Posts 3,980 looks a bit like them old v8 coolers or whatever they were called, but nicer looking i like the pink
10 Jan 2013 at 14:52 #6 isonomicjedi isonomicjedi Associate OP Joined 30 Dec 2012 Posts 1,153 Location midlands Haha I'd left Prime running when I hadn't meant to (must be 30 minutes) and core temps went up to high 50's 58,56,56,57 I think thats good doesn't it?
10 Jan 2013 at 14:57 #7 chrisoverson chrisoverson Associate Joined 16 Nov 2012 Posts 252 That's fine Lower temperatures are always better of course, but the max you want it to reach ideally with ivybridge is around 80 degrees. 56-58 is good.
