800D Extreme Modding - Experienced Input Needed :)
i had a look at the koolance mount also but decided with the stand, not noisy at all got 4 gentle typhoons running at 40% cant hear a thing, only fan noise i get is from the PSU now :D The external is an XSPC AX480 and the temps i get are great, never have to push the fans past 40%.
Its a pain but only requires emptying the system putting card in. Reconnect everything then refill loop.
seems reasonable enough, I only ask as I am not 100% sold with my GPU. 2GB and if i go down the 3D surround route I might kick myself if I SLI it so not getting a 2nd card until I am sure I am happy. Just dont want to have to decide before I start the loop.
The stand is reasonably priced too. I will look into this, is it safe? You ever knocked it over? I imagine the tubing keeps it from fully falling?
I am sure I could fit it next to my PC without any issues but it would worry me a bit the fact its external.
