do the cost benefits of an overclock wake sense?
12 May 2004
England
if you factor in the cost of higherend cooling and CPU cost does the gains (for gaming) increase over a non overclocking CPU make sense as most benchmarks the difference is negligible isn't it? with the VGA being the most important factor?
It depends on the use, some CPU-intensive tasks/games it makes a lot of difference, some it doesn't.
You'll get the same argument when overclocking a GPU also.
for me yes, less cost/more power, good cooling gives same amount or less noise than default fan etc and i got it done at source so no agro and better warranty :)
ie none if you do it yourself and it blows :)
Air cooling, probably. Certainly lowering the voltage and upping the speed a bit on the stock cooler is pretty low cost, provided you bought a remotely decent motherboard.
Watercooling, probably not. You do it for quiet or for performance, not for cost.
There are several excellent sub £30 coolers out there, and even if I wasn't an overclocker I'd want a very quiet system, so would have decent cooling anyway. Before Intel decided to lock down most of their CPUs, there were great gains to be had. Now it's more for sport :p
The argument I always put forward in the "PC gaming is too expensive" threads is this - without gaming I'd still need a fast PC, I'd still want a big monitor, I'd still want it to be damn silent - PC gaming costs me the price of the video card, my current one was far cheaper than either the PS3 or Xbox 360. Same with overclocking
Thing is, you cant stock CPUs as fast as a low end OCed one.
If they released top end CPUs at stock 4 or 5Ghz then you may be able to argue it. But they dont so the only way to get those levels of performance is to overclock :D
I've never noticed any difference in my main rigs performance with it's large overclock. I don't do any encoding or rendering with it so I presume I'm not CPU limited by most of the things I do. I enjoyed doing it though which for me is the whole point :)
Eh???? If it blows unless youexceed voltage reccomendations 1.6v? Your covered.
