**Today Only 11/01/2013** Kingston HyperX Blu 16GB (lowest price in UK) & £30 off KFA2 GeForce GTX 6
22 Aug 2010
KFA2 GeForce GTX 680 LTD OC V4 2048MB GDDR5 PCI-Express Graphics Card **ALL WHITE** @ £419.99 inc VAT
The KFA2 GTX 680 OC LTD is based on a white PCB with two 8 pin PCI-E power connectors for a maximum TDP of 300W for immense overclocking. Further, it is cooled with three 90mm fans and five heatpipes leading to an aluminum fin array. The card will come equipped with dual BIOS support and overclocking software. With higher power TDP, better cooling and far superior power phase along with a custom GX31 processor for software voltage control this will be one if not the best clocking GTX 680 on the market.
The GeForce® GTX 680 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA
FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- KFA2 Own White-PCB Design GeForce GTX 680
- Innovation Cooler Design giving powerful yet silent cooling with 3x 90mm fans
- Extreme Overclocking Performance
- 8-Phase Core PWM (8+2+2)
- 2+2-PhaseMemory PWM
- Galaxy custom GX31 chip with software voltage control, voltage monitoring and power draw monitoring
- Core Clock: 1110MHz (GK104)
- Core Boost Clock: 1176MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2220MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 1x DisplayPort, 3x HDMI 1.4a (300Mhz Transmitter for 120Hz)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- 2x 8-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 2 Years
Only £419.99 inc VAT.
ORDER NOW
Kingston HyperX Blu 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (KHX1600C10D3B1K2/16G) @ £47.99 inc VAT
Kingston's KHX1600C10D3B1K2/16G is a kit of two 1G x 64-bit (8GB) DDR3-1600 CL10 SDRAM (Synchronous DRAM), 2Rx8 memory modules, based on sixteen 512M x 8-bit FBGA components
per module. Total kit capacity is 16GB. Each module kit has been tested to run at DDR3-1600 at a low latency timing of 10-10-10 at 1.65V.The SPD's are programmed to JEDEC standard latency DDR3-1333 timing of 9-9-9. Each 240-pin DIMM uses gold contact fingers. The JEDEC electrical and mechanical specifications are as follows:
- Kingston Blu KHX1600C10D3B1K2/16G
- 16GB Kit - 2x 8GB Modules
- DDR3-1600
- CL10
- 1.5v
- 240pin
Only £47.99 inc VAT.
ORDER NOW
Do KFA speed bin the chips on that particular model? It seems a huge premium to pay when you can get a stock MSI GTX680 for £354 which has a 3 year warranty instead of just 2.
Been looking all week for another deal on RAM so thanks for that. 32GB will do nicely.
Well, time will tell. They are obviously getting some good pricing on it.
This is our last 30 or so units now, we had 5000 kits just before Christmas which we got at November pricing.
Our actual cost is now nearly double what it was and this special price is below the re-buy price.
Also memory pricing will continue to increase most likely until end of February, so its going to get more expensive in the short term.
