Nvidia Quadro and Tesla now available at OcUK
20 Jul 2009
The bleak North East arm pit of Britain
Hello
After launching the FirePro last week, OcUK has now launched the Quadro and Tesla range. The range at the moment isnt the biggest but this is set to grow as Quadro and Tesla become more popular. Check out the cards below along with the truly awesome Tesla K20 :D
PNY Nvidia Quadro 410 Graphics Card - 512MB - GDDR3 SDRAM @ £124.99 inc VAT
NVIDIA® Quadro® 410 GPUs combine outstanding workflow productivity for entry CAD/PLM users, comprehensive professional application certifications, and the peace of mind professionals have come to expect from NVIDIA Quadro products – all at an exceptional value.
- Shader Model 5.0.
- OpenGL 4.2.
- Microsoft® DirectX 11.
- NVIDIA CUDA Parallel Processing Architecture.
- NVIDIA® nView® multi-display technology.
- NVIDIA® Mosaic technology.
- 512MB Vram
- 64 Bit GDDR3
- 38W
- 1x DisplayPort
- 1x Dual Link DVI-I
- Max resolution: 3840x2160
- 192 CUDA Cores
Only £124.99 inc VAT.
ORDER NOW
PNY Nvidia Quadro 600 Graphics Card - 1GB - GDDR3 SDRAM @ £158.99 inc VAT
NVIDIA® Quadro® 600 by PNY Technologies - Low-profile, power-efficient, professional graphics solution
Built for Professionals™, and certified on leading CAD and DCC applications, NVIDIA Quadro 600 by PNY delivers the best performance per watt in its class, maximizing productivity while conserving energy.
Designed for both small form factor and full height workstations, the NVIDIA Quadro 600 by PNY delivers advanced capabilities, allowing you to design, iterate and deliver higher quality results in less time.
- Frame Buffer Memory: 1GB DDR3
- Memory Interface: 128-bit
- Memory Bandwidth: 25.6 GB/s
- CUDA Parallel Processing Cores: 96
- Display Connectors: DVI-I (1), DP (1)
- Max Power Consumption: 40 W
- Graphics Bus: PCI Express 2.0 x16
- Form Factor: Low Profile - 2.731” H x 6.6” L Single Slot
- Thermal Solution: Active
- 3D Vision Pro: Support via USB
Only £158.99 inc VAT.
ORDER NOW
PNY Nvidia Quadro 2000 Graphics Card - 1GB - GDDR5 SDRAM @ £419.99 inc VAT
Delivering the industry’s best-in-class performance across leading CAD and DCC applications, the NVIDIA Quadro 2000 by PNY mid-range professional graphics solution features Scalable Geometry Engine™ technology and 1GB of memory for fast processing of complex models and scenes.
With Quadro solutions your work flows – design, iterate and deliver higher quality results in less time.
- Frame Buffer Memory: 1GB GDDR5
- Memory Interface 128-bit
- Memory Bandwidth 41.6 GB/s
- CUDA™ parallel processing cores: 192
- Display Connectors: DVI-I (1), DP (2)
- Max Power Consumption: 62 W
- Form Factor: 4.376” H x 7” L Single Slot
Only £419.99 inc VAT.
ORDER NOW
PNY Nvidia Quadro 2000D Graphics Card - 1GB - GDDR5 SDRAM @ £399.98 inc VAT
Delivering the industry's best-in-class performance across leading professional ISV applications, the NVIDIA Quadro 2000D by PNY features two dual-link DVI connectors to drive two ultra-high-resolution panels and add flexibility for multi-monitor configurations. Professional applications can take advantage of the Quadro 2000D advanced feature set, including Scalable Geometry Engine™ technology, 192 NVIDIA CUDA™ parallel processing cores and 1GB of memory for fast processing of complex models and scenes.
The NVIDIA Quadro 2000D by PNY also delivers the industry's most advanced diagnostic imaging graphics solution. Offering two dual-link DVI connectors for display flexibility, support for 10/12-bit grayscale monitors up to 10Mpixels, and DICOM monitor calibration capabilities – the Quadro 2000D enables more confident medical analysis.
Based on NVIDIA's award-winning Fermi Architecture, the Quadro 2000D delivers advanced capabilities including Mosaic Technology which enables any application to scale across up to eight displays using multiple Quadro graphics boards.
- Memory Size: 1 GB GDDR5
- Memory Bandwidth: 41.6 GB/s
- CUDA Parallel Processing Cores: 192
- Display Connectors: DVI-DL + DVI-DL
- Maximum Power Consumption: 62 W
- Physical Dimensions: 4.376" H x 7.0" L Single Slot
- Warranty: 3 Years
Only £399.98 inc VAT.
ORDER NOW
PNY Nvidia Quadro 4000 Graphics Card - 2GB - GDDR5 SDRAM @ £719.99 inc VAT
Offering 2GB of GDDR5 graphics memory, 256 NVIDIA® CUDA™ parallel processing cores and built on the innovative Fermi architecture, the NVIDIA Quadro 4000 by PNY is a true technological breakthrough delivering excellent performance accross a broad range of design, animation and video applications. Using the Quadro 4000 graphics solution your work flows; you can design, render and deliver high quality projects in less time.
The NVIDIA Quadro 4000 by PNY graphics board significantly raises the bar for high performance visualization and computation providing Microsoft DirectX 11.0 and Shader Model 5.0 hardware acceleration and the ability to drive a variety of display types including: CRTs, Digital Flat Panels, Projectors and HDTVs.
- Memory Size: 2GB GDDR5
- Memory Interface : 256-bit
- Memory Bandwidth : 89.6 GB/sec
- Max Power Consumption : 142W
- Number of Slots : 1
- Display Connectors : DVI-I + DP + DP + Stereo (extra bracket)
- Dual-Link DVI : 1
- 256 Cuda Cores
Only £719.99 inc VAT.
ORDER NOW
PNY Nvidia Quadro K5000 Graphics Card - 4GB - GDDR5 SDRAM @ £1,819.99 inc VAT
The NVIDIA® Quadro® K5000 taps into the new NVIDIA Kepler architecture to deliver the world’s most compatible and power-efficient GPU for accelerating professional applications.
You can count on superior interaction when designing with the most complex models, richer scene details and effects for content creation, and faster results when processing massive datasets for scientific exploration. The Quadro K5000 features a range of innovative features, including SMX for increased per-clock throughput of key graphics operations and bindless textures that enable the GPU to reference textures directly in memory. Plus, it supports up to four displays—ideal for driving large-scale visualization solutions.
Easily deploy ultra-high resolution scalable visualization configurations.
You can now drive up to four displays simultaneously and get full support of the next-generation DisplayPort 1.2 standard—capable of resolutions of 3840x2160 at 60 Hz. This makes it easy to deploy multiple displays across a desktop, build an expansive digital signage wall, or create a sophisticated stereoscopic 3D CAVE environment. NVIDIA’s latest technologies, coupled with a Quadro K5000, give you an easy, affordable way to perform image synchronization and resolution scaling of a synchronized display surface with multiple projectors or displays. These technologies include Quadro Sync, Quadro Mosaic, Quadro Warp/Blend, and GPUDirect.
Interact with greater levels of model complexity in the design workflow.
The Quadro K5000’s next-generation streaming multiprocessor (SM) design, called SMX, offers several important architectural changes. These include substantial increases in per-clock throughput of key graphics operations that combine to deliver unprecedented performance and power efficiency. Plus the Quadro K5000 features large frame buffer capacity that lets you work with larger models and assemblies and improves interactive manipulation performance during the design process.
Create richer scene details and effects for content creation.
The NVIDIA Kepler architecture introduces the concept of bindless textures, which enables the GPU to reference textures directly in memory. This effectively eliminates the limit on the number of unique textures that can be used to render a scene, and reduces the CPU overhead to deliver improved performance. In fact, over one million unique textures are now possible. FXAA and TXAA film-style antialiasing technologies also optimize throughput of the SMX architecture, so you get outstanding image quality for content creation and design reviews without compromising the interactive experience.
Certified on industry-leading professional applications.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 150 professional applications across a broad range of industries, including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to deliver the best possible experience with applications such as Adobe CS6, Avid Media Composer, Autodesk Inventor, Dassault Systemes CATIA and SolidWorks, Siemens NX, PTC Creo, and many more. For maximum application performance, add a Tesla K20 to your workstation and experience the power of NVIDIA Maximus technology.
- 1536 CUDA Cores
- 256 bit 4GB GDDR5 Memory
- 2x DisplayPort
- 1x Dual Link DVI-D
- Max Resolution 3840x2160
- Retail
Only £1,819.99 inc VAT.
ORDER NOW
PNY Nvidia Tesla K20 Workstation Solution Graphics Card - 5GB - GDDR5 SDRAM @ £2,999.99 inc VAT
With teraflops of single and double precision performance, NVIDIA® Kepler GPU Computing Accelerators are the world’s fastest and most efficient high performance computing (HPC) companion processors. Based on the Kepler compute architecture, which is 3 times higher performance per watt than the previous “Fermi” compute architecture1, the Tesla Kepler GPU Computing Accelerators make hybrid computing dramatically easier, and applicable to a broader set of computing applications. NVIDIA Tesla GPUs deliver the best performance and power efficiency for seismic processing, biochemistry simulations, weather and climate modeling, image, video and signal processing, computational finance, computational physics, CAE, CFD, and data analytics.
• SMX (streaming multiprocessor) design that delivers up to 3x more performance per watt compared to the SM in Fermi. It also delivers 1 petaflop of computing in just 10 server racks.
• Dynamic Parallelism capability that enables GPU threads to automatically spawn new threads. By adapting to the data without going back to the CPU, it greatly simplifies parallel programming and enables GPU acceleration of a broader set of popular algorithms, like adaptive mesh refinement (AMR), fast multipole method (FMM), and multigrid methods.
• Hyper-Q feature that enables multiple CPU cores to simultaneously utilize the CUDA cores on a single Kepler GPU, dramatically increasing GPU utilization, slashing CPU idle times, and advancing programmability. Ideal for cluster applications that use MPI.
- 2496 CUDA Cores
- 706MHz Core Clock
- 320Bit GDDR5
- 5GB Memory
Only £2,999.99 inc VAT.
ORDER NOW
