Are the stock fans ok or should I invest in something better?
I used to have Apaches on my H50, would it be beneficial to do the same with the H80i. Also should it be set to intake or exhaust, I currently have it set to exhaust in a 600T case.
It's cooling a 3770k.
(an expensive migrate
, mini-itx MB's are expensive if you want overclocking ability...going to cost like £200 for the case+mb) use a cheap old artic freezer 7 pro atm.
