- 5 Jun 2003
- sawley/ long eaton
shouldnt be the kit lens, more likely settings
Only niggle is the image quality, I assumed it would be on par with my lower MP bridge cameras in terms of noise performance however, the photos I've taken around the house so far are fairly grainy when zoomed in on, even at varied ISO settings and lighting. Perhaps it's the limited kit lens? New to DSLRs so don't shoot me down![]()
Really? That's not my understanding from paper point of view (wearing my engineer hat!) and yes I appreciate this might be in the "someone is wrong on the internets" relm.The sensor in the d5100 is about the best money can buy in the crops sensor size, heck it is not so far behind last generation full frame.
It also isn't true from DxO labs testing either.
http://snapsort.com/compare/Nikon-D5100-vs-Pentax-K-30
In fact the D5100 sensor is distinctly average at best. I'll ascert that statement with the fact it is worse than cheaper sensors.
However we live in a such a great age that a cheap average sensor should deliver top results.
OP if you try posting a full res JPG or even a RAW file showing the problems your having I think people might be able to suggest. Also, you've updated the firmware right? They did have a couple of quirks which could compromise the quality:
https://nikoneurope-en.custhelp.com/app/answers/detail/a_id/50626/~/d5100-firmware-update-1.01
Always worth checking for new firmware.
Anyone tried the new 5200? I noticed that the price has dropped considerably, to same/less than d7000. I have not seen many reviews, but cropping a 24mp image seems tempting as I often trim my images (tried a 3200 and was impressed with its snappyness against my trusty bridge cam).
You're better off buying a longer lens so you get the composition right in the first place. I would get the D7000 over the D5200 any day though. It's better in virtually every respect.
I think it was just my noobness with the camera in this instance!
On 'auto' it sets the ISO to auto and indoors, seems to select somewhere in the region of 3000+. Which is very strange, even when the room is well lit or I point the camera directly at the light, it still reads ''SUBJECT TOO DARK'' on the screen.![]()
When it's in manual and I set the ISO to 100, the images are crisp and clear but only with incredibly fast shutter speeds, meaning everything is too dark...even well lit areas... again, just figuring out the camera!
I still think it's strange that the camera finds everything too dark though, even strong light sources.
I don't know. In doors pointing at a light surely it shouldn't be to dark.
I can take indoor shots at iso800 (Nikon D50) at around f2.
