im not sure on that board,you could try raising power limits a little see if that helps,you can still use a touch more dram v upto 1.575,
disabling cpu spread spectrum might help also
The general consensus over the net is that my power limits should be fine. I'll try disabling spread spectrum and run prime.
*edit* I have now re-set the DRAM voltage and the VTT voltage to the standard 1.50v and 1.051v while I prime with spread spectrum disabled just to check it like this first.
I am honestly expecting it to BSOD at this point. I may install an OS on a secondary drive while this continues so that when i'm playing around in the BIOS, the inevitable BSOD's won't damage my main OS.
Is it at all possible that priming with the temperatures 78, 80, 85, 83 could be the cause? I do still need to clean out the radiator. I went to grab a can of compressed air in town but I couldn't find any, so I ordered some. It isn't here yet.
*edit* I just opened my window. It's freezing in here now but the temperatures have dropped to something a bit more 'prime-friendly'.
Temps should drop 8°C - 12°C once the radiator is all cleared out.
