Hot water burn, debating the hospital...
The fact that you refer to it as a burn suggests you should go to A&E as well. Let them slather that cream on ;-)
The best thing you did was to smother it with cold water though...
Just finished at the A & E. They applied some new dressing they are trialling, I was told I'm the first one to be using it as the rep came on this morning.
They told me to use Vaseline on my other area.
This, gentlemen, is what happens if you activate your boxing stance with a cup of boiling water in your hand....be warned!
