i'm not at home this weekend so i cant RMA it till next week,
its the Panny st 50
1...it has two horizontal grey blotches in the top right hand side, these only show in the whites and while the screen pans upwards, but they're there all the time.
2...it has horizontal lines going across the screen whilst gaming while you run forward, these look like pixel waves and they're stacked vertically, it's like a mirage/ shimmering....this is also present in normal tv
3... there's quite a lot of noise as the screen pans around, there's quite a lot of pixel movement, you see brightness changing in the whites.... there's no motion blur, instead; the pixels look slow to adjust to variations in brightness, it looks like circular/ oval banding, you see it as the tv looks at a sunset or a bright light source.
these faults are starting to bug me, but NO 1 is a definite fault in the whites and this wasn't there yesterday.
its the Panny st 50
