**NEW** Prolimatech Megahalem Blue & Red series [Available for Pre-order]
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Without much confusion or doubt, the unmistakable shape of the Prolimatech Megahalem has returned. This time we see the cooler with nice new shades of colour, a very vibrant metallic blue and red finished with matte-black top-fins which are now capped with metal instead of exposed. Keeping the same dimensions as the classic Megahalem (L)130mm X (W)74mmX (H)158.7mm, you can expect the same cooling performance. All current CPU socket types are supported. The new shades will really add that extra aesthetic aspect to your build.
We now list these coolers for pre-order!
Prolimatech Red Megahalems CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £52.99 inc VAT
By popular demand, the ever popular Megahalems now comes in Red! It has stylish black grainy matte finish for the best looking performance. If looks could kill, this heatsink would reap havoc on any competitor in its path!! Housing this Intimidator is a specially designed package that has every look of a “Collector’s Edition”! Inside the package you get not only one but two sets of fan clips for setting up an awesome arsenal of duo fans. You also get support for installation on any of the Intel's and AMD's recent platforms. Those include Socket 775, 1366,1155/1156, and of course, the newest 2011, and AM2/2+/3/3+. No longer will you have to choose which backplate to use because a specially designed universal backplate has been created for better convenience and better cooling results. What Megahalems has set in performance standards, now Black Megahalems will raise the bar one level higher! Everything else aside, if looks are everything to you, this is the one heatsink to get!!
- Stylish black grainy matte finish for the best looking performance.
- Top fin made of scratch-resistant Stainless Steel to preserve shine.
- Minimal air resistance between fins allowing best balance between noise and performance in range of . - For all out performance, fan RPM at 1600 or above is recommended.
- Heatpipes are lined up in a straight line to prevent air back draft allowing air to easily pass through the heatsink body.
- Wide gaps between fins with mathematically calculated thickness to maximize best air-to-surface cooling rate.
- Easy-to-install retention mechanism for LGA 775, 1366, 1155, 1156 and 2011 and AM2/AM2+/AM3/AM3+.
- Includes easy-to-apply high grade thermal compound, a perfect sidekick to all Prolimatech heatsinks.
- New Universal Backplate to support all Intel platforms.
- Two sets of fan clips for a duo-fan installation
- Heatsink Dimensions: (L)130mm X (W)74mmX (H)158.7mm
- Heatsink Weight: 790 g
- Heatpipes: 6mm X 6pcs
- Suggested Fan: 120mm x 120mm x 25mm or 140mm x 140mm x 25mm
- Suggest Noise Level (dBA): Below 26dBA
- Air Flow: 57 CFM
- Direction of heatsink: Faces the rear exhaust system fan
- CPU Platform: Intel Socket LGA 775/1366/1156/1155/2011 , AMD Socket AM2/2+/3/3+
Only £52.99 inc VAT.
ORDER NOW
Prolimatech Blue Megahalems CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £52.99 inc VAT
By popular demand, the ever popular Megahalems now comes in Blue! It has stylish black grainy matte finish for the best looking performance. If looks could kill, this heatsink would reap havoc on any competitor in its path!! Housing this Intimidator is a specially designed package that has every look of a “Collector’s Edition”! Inside the package you get not only one but two sets of fan clips for setting up an awesome arsenal of duo fans. You also get support for installation on any of the Intel's and AMD's recent platforms. Those include Socket 775, 1366,1155/1156, and of course, the newest 2011, and AM2/2+/3/3+. No longer will you have to choose which backplate to use because a specially designed universal backplate has been created for better convenience and better cooling results. What Megahalems has set in performance standards, now Black Megahalems will raise the bar one level higher! Everything else aside, if looks are everything to you, this is the one heatsink to get!!
- Air Flow: 57 CFM
ORDER NOW
Very nice, but points lost for a non-matching top plate. And since it's the bit you'll mainly be seeing...
Still waiting for one of the big guns to do a green heatsink too.
Do these come with socket 2011 fittings as prolimatech's site say that you must purchase the optional 2011 fitting kit?
These look great, I really want some colour with my next cooler.
Like Uncle Petey green would be my preference, so will have to wait or maybe go with original black
Nice,Although i think the Megahalems are overrated,and expensive for just the heatsink.
Trying to get the most out of Air cooling is quite consuming, if you certainly don't want fluid going around your components, then you want to get the most efficient air cooling solutions?
Not that I would part with that much for a heatsink for a CPU, but still.
