What voltage do people use to obtain decent overclocks?
Just for the record and not to **** you off but both my cards do 1400+Mhz (sorry, I had to slip that in)
About 440volts in the case above![]()
1250 is considered a semi decent overclock. I have seen cards smash past 1350 and others not reach 1150. Chip lottery at its finest.
Thanks and **** you at the same time haha
My cards are already FTW versions, but both have different clocks when OC'd to the same amount. Weird.
Also, what settings do you use for GPU clock offset and Mem clock offset?
I cannot get my cards to go over 1250MHz
Thanks in advance for any advice
The Kepler cards boost to different frequencies out the box.
Does the slot you would put a single card in make that much of a difference to overclocks? I have a single 680 in the lower of my mobo's two 16x pice slots, mainly for ease of water cooling. It is a pretty bad clocking card I can only get +60 on the core, but would putting in the top slot make a difference? I thought that since both slots were 16x that they should peform the same. Is only relevant with SLI?
