Can i run 3 eyeinfinity screen with the 7950 and a fourth and 5th screen with the 560?
You can use either a single 7950 for eyefinity for 2 in crossfire for extra performance. To add that 4th or 5th screen, you will need to use a separate card again. As its only driving a screen, I'd recommend getting a low powered card for that purpose.
So your choice would be 1 x 7950 + another card or 2 x 7950 + another card.
