Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor - OEM @ £199.99 inc VAT
Dominate your gaming competition the unleashed and uncompromised Intel Core i7 series. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA2011
- Quad Core
- Frequency: 3.60GHz (3.90GHz TURBO)
- Multiplier: 36x (Upto 43x available)
- L2 Cache: 4x 256KB
- L3 Cache: 10MB
- TDP: 130W
- 1yr Warranty
Only £199.99 inc VAT.
ORDER NOW
Samsung Green (MV-3V4G3D/US) 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit @ £41.99 inc VAT
nonl2br
These Samsung Green kits are a world first using 30nm technology. This results in lower power usage, extended life and ultra low profile making them compatible with all DDR3 solutions including small form factor.
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 8 GB capacity (2 DRAM modules, each with 4 GB).
The other major advantage of these modules is their overclocking ability, in our own testing we achieved 2400MHz with CAS 11-11-11-28-1T timings with just 1.55v resulting in staggering levels of performance.
Features:-
- Model Name: MV-3V4G3D/US
- Main Board: INTEL/AMD
- System: DESKTOP/SFF
- System Type: DDR3
- M/B Chipset: INTEL P67, Z68, Z77, X79 & AMD Chipsets
- CAS Latency: 11-11-11-28 1N
- Capacity: 8GB (4GBx2)
- Speed: DDR3-1600 (PC3-12800)
- Test Voltage: 1.25-1.55V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 240-pin DIMM Low Profile
- Warranty: Lifetime
Overclocking Features (Not Guaranteed)
- 1600MHz (7-8-8-24 1N) @ 1.40v
- 1866MHz (9-9-9-27 1N) @ 1.40v
- 2000MHz (9-10-10-28 1N) @ 1.45v
- 2133MHz (10-10-10-28 1N) @ 1.45v
- 2400MHz (11-11-11-28 2N) @ 1.50v
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M
Only £41.99 inc VAT.
ORDER NOW
- Core Size: 32nm
- Socket: LGA2011
- Quad Core
- L3 Cache: 10MB
- TDP: 130W
- 1yr Warranty
ORDER NOW
nonl2br
Features:-
- System Type: DDR3
ORDER NOW
