- 18 May 2010
- London
To pass certification, the app must score at least 11 out of a possible 18 points across the three tested categories; MSE scored 10 and so just managed to fail the criteria
Think first, click after. You most likely already come across infected sites or malicious ad banners through your regular browsing but it’s not a reason to click on any links you receive in emails, Facebook or Twitter.
Use your browser wisely: Regular web surfing should have the Java plugin disabled to minimize the infection risk. If for some reason you must use it for a particular site or application, re-enable it as needed or simply use a different browser with Java enabled. There is a tutorial here. Also, if you are logged into your banking website, refrain from opening a dozen other websites in tabs at the same time. Certain sites can load Cross Site Scripting attacks (XSS) and hijack your banking session.
Install the latest version of every software and set settings to automatic update. For Adobe Reader, open a PDF and go to Edit->Preferences->Updater. For Flash go to Control Panel->Advanced. For Java, use this guide.
Backup your data. At the end of the day, you may love your computer but if you really think about it, the stuff that’s on it is actually more valuable. You can always buy a new PC, but you can’t say the same about pictures, work documents, etc…
Hopefully these tips will help to make your computing experience safer because the bad guys are not going to rest any time soon.
Thanks for the RSS....
Avast is the only free AV you will ever need, far superior to MSE.
Issue
If avast! 7.0.1473 or 7.0.1474 is installed on Windows 8 you may experience a blue screen error (BSOD) in NETIO.SYS or ASWNET.SYS driver.
Details
This is a known bug in avast! 7.0.1473 and avast! 7.0.1474 running on Windows 8. The problem should be fixed with the updated ASWNET.SYS driver.
