Hello people,
I've currently got my gear inside a tower, but the PC is being moved into a my living room to sit with the TV and AV receiver, so I want to put it all into a HTPC case without changing any components.
The case need to take ATX form, Noctua NH-D14 (about 160mm height I think), and suitable for a 280mm gfx card. Must be black in colour.
I'm not really fussed about any HTPC features tbh. I just want a case that's designed to sit horizontally, therefore I really would be looking at spending £200 at the absolute most, but would prefer half of that.
None of the Silverstone cases appear to be tall enough, and I thought I had found what I was after in one of the Lian Li cases, but I found a thread elsewhere showing a guy having to mod his case to get it to fit, so that was out as well. I would rather not have to go down the route of cutting holes in a case.
The only thing I have found is the Antec Fusion Remote Max, but it's an older case that I can't find for sale anywhere I can be sure is trustworthy, or under the £200 mark.
http://store.antec.com/Product/enclosure-veris_media/fusion-remote-max/0-761345-15727-8.aspx
I would really appreciate any suggestions on finding the right case.
Cheers.
Cheers.
