fx4100 throttling back
18 May 2011
Hi everyone
Just built the system and all was well until i tried to overclock it lol
First i thought id just stress test the cpu before hand with prime95 to see if all was well
The cpu keeps throttling back to 3.3ish ghz and wont even hit the 3.8 turbo
Ive disabled all the usual stuff and the thermal control but my problem is still there
Ive updated to the latest BIOS aswell and its exactly the same as before
Been googling around for a bit but i cant find any fix :(
Anyone have any ideas that i could try?
Thank you
EDIT
Sometimes it even throttles back to as low as 2.5ghz :(
Since when?
Prove your point
They've been this way for ages.
It's not rare to see them report sub ambient temperatures.
At their TDP, the temperatures also aren't that realistic, so, while you may think "My AMD only gets to 62c, whereas the Intel will get to 80c" that 62c isn't really 62c, unless of course a CPU with more heat to get rid of, under the same cooler, can run cooler than the lower TDP CPU :p?
That has a heatsink on the VRM too. A number of the Gigabyte 900 series motherboards had the same throttling issues which were fixed via a BIOS update IIRC.
Edit!!
However,I would still try a fan to see if more VRM cooling helps.
what psu?
id try reflashing with the same bios aswell,bios settings seem to not save on these newer gigabyte boards(z77 anyways) reflashing the bios and entering oc settings fixes it
idk if thats the case for amd/gigabyte boards
what psu?
be quiet 530w mate
just reflashed the bios and the same thing is happening lol
Fix the vcore at about 1.4-1.45V and see if that fixes it. It sounds like the voltage is dropping under load. LLC may help if you can change the settings higher. Do not leave cpu voltage on Auto.
If the Voltage was dropping to much wouldn't it just BSOD?
Are you thinking that the auto voltage setting is control the turbo feature (turning it down to sit at lower voltages)?
Has the OP tried manually setting clock speed and vcore?
Not tried that mate
Time to got into the bios again
Ill report back :D
