Just installed GTX 560ti twin frozr ii NO SOUND
18 Jan 2013
I installed my GTX 560ti twin frozr edition and now i have no audio
Here is a Gyazo of my audio ect:
http://gyazo.com/7c53b11c40d766edff264eee8483e3f7
It says that they are working ect on the control pannel and sound bars move up and down but nothing through speakers.
Recording gyazo
http://gyazo.com/5b585ab9db9590603467e2f3fd7baa54
And again it still says that they are working. wtf
Heres what my Device manager looks like:
http://gyazo.com/f5d195b17b3232b98d79db38dbb59129
Heres what my Realtek HD Audio software looks like:
http://gyazo.com/4dd5e835e4bebc0047a685865e6e77f8
So i got home plugged my GFX Card in worked fine sound ok, The next day i came home from college and boom no sound i put old GFX Card in, nothing, Re installed windows 7, nothing, re installed nvidia driver/realtek hd audio drivers, still nothing FFs pleas help me :@ no silly comments pleas.
Have you tried reinstalling Nvidia drivers/custom and don't install the Nvidia audio drivers (untick the audio box)? or is that a silly comment :p
If the sound is connected to the onboard sound (which it looks like it is on the Realtek screenshot), it's because the Nvidia GPU has been set as the default sound device, which only works when the HDMI monitor has speakers. Select "Realtek Digital Output" and set it as default.
But then if he is using Optical he will still have no sound:p
Silly that people post posts like this asking for help with sound without posting how its actually connected up:confused:
Well it was connected to my monitor through a DVI cable from GFX Card and the i changed to my tv/miniHDMI<bigHDMI adapter its not a cheap one its not an old one i just got it
So your trying to play the sound through your TV?
DVI doesnt carry sound so it's still unclear how your sound setup was before and is now.
You really should post how your speakers is connected to the PC :p.
If trying to play from TV speakers -> Nvidia High Definition Audio as default.
If from speakers connected to the onboard Realtak -> One of the three Realtek ones as default.
Just done that i am not good with pc's, if you would kindly help me over Skype,Teamspeak would be helpfull skype is tom-aam-1995
now i am on monitor, and set realtek control pannel to digital output and on sound i put digital output and still nothing from speakers all pluged in and stuff but nothing
done that and still nothing skype tom-adam-1995
It's pretty simple really:
Select "Realtek Digital Output" which I highlighted in the red arrow. Then press the "Set default" button I circled in red. If that doesn't work, try again but with "Realtek Digital Output(Optical)" and see if it works with that.
EDIT: Just saw you posted this:
now it is connected to DVI<monitor<and speakers to Green back pannel
Then do the same steps but choose "Speakers" instead.
yep i am not good with pc/problems and do not really want to go to pc specialist and pay £50 for them to tell me i didnt have something correctly :) skype tom-adam-1995 if you wanna try teamviewer and see
skype tom-adam-1995 come see for yourself i done that but it not working if you can come over to skype and teamviewer and have a look for me would be amazing dude thanks
