Hi there
This new superb monitor from DELL Is now in stock!!
Dell UltraSharp U2413 24" Widescreen LCD Monitor - Midnight Grey @ £479.99 inc VAT
Experience the latest technology with the DellTM UltraSharp U2413 60.96 cm (24") high-performance monitor for consistent colours right out of the box.
Features:-
- Remarkable screen quality : Count on consistent, calibrated hues with PremierColour, WQHD, up to 1920 x 1200 resolution and a 120% colour gamut.
- Stunning colour precision and performance : U2413 with PremierColour comes factory colour calibrated to support 99% AdobeRGB which enables brilliant and accurate colour hues and saturation. Six axis colour control enables further user customization, professional colour critical work.
- Superb user experience : Convenience is at your fingertips with multiple connectivity ports, including USB 3.0, DisplayPort 1.2, mini-DisplayPort, DVI-D (HDCP) and HDMI.
Specification:-
- Diagonal Viewing Size: 24" (60.96 cm)
- Aspect Ratio: 16:10
- Panel Type, Surface: AH In-plane switching, anti glare with hard coat 3H
- Optimal Resolution: 1920 x 1200 at 60 Hz
- Contrast Ratio: 1000 to 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
- Backlight Technology: LED
-Brightness: 350 cd/m2 (typical), 50 cd/m2 (minimum)
- Response Time: 6ms (grey to grey)
- Max Viewing Angle (178º vertical / 178º horizontal)
- Colour Support: Colour Depth: 1.07 billion colours
- Colour Gamut (typical): Adobe RGB 99%, sRGB 100% and 120% (CIE 1976)3
- Pixel Pitch: 0.27 mm
- Connectivity: 1x DVI-D, 1x DisplayPort 1.2, 1x Mini DisplayPort 1.2, 1x HDMI
- USB3.0 Hub
- VESA Supported
- Height-Adjustable stand, tilt, swivel, pivot and built-in cable-management, capacitive touch OSD controls
- Dimensions (W x D x H): 556.0 mm (21.89") x 200.5 mm (7.89") x 415.9 mm (16.37") ~ 530.9 mm (20.90")
- Weight: 9.35kg
- Warranty: 3yr on-site
Only £479.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- USB3.0 Hub
- VESA Supported
- Weight: 9.35kg
ORDER NOW
no wonder 2413 will be 500-ish
