Morning guys,
So, as the post title states, I'm looking to overclock my AMD Piledriver FX-8350.
I've seen it's possible to safely go up to around 4.0-4.2Ghz.
PC Specs:
CPU: AMD Piledriver FX-8350
Mobo: ASRock 990FX Extreme3 990FX
RAM: Corsair Vengeance 16GB DDR3 PC3-12800C9 1600MHz
Heatsink: Noctua NH-D14
GPU: ATI Radeon HD 5870
Case: Zalman Z11 Plus
I've heard the motherboard isn't the easiest to overclock, but I'm guessing most of the settings are pretty much the same.
I guess what I'm asking for is if anyone would be able to help me with overclocking? I've had very little experience in the past with it, but I'm aware of the basic things you need to do after Overclocking like running an a couple of hour of Prime95 to check temps/stability.
Just looking for a bit more information around how to start increasing my CPU Ghz safely & slowly.
I'm also looking to be purchasing the Antec Kuhler H2O 920 or the highly anticipated Swiftech H220 CPU coolers by the end of the month.
Hope someone can help.
Thank you. Ryan
PC Specs:
Thank you. Ryan
