-7 tonight, how low can diesel go?
bit off topic but does anyone know why these last couple of really cold weeks my mph has gone from 44mpg to 38mpg doing the exact same trips
Air is denser and therefore more fuel is added to maintain the correct fuel to air ratio. If it is a petrol then you have the extra effect of longer warm up period where more fuel is added as well.
its diesel
You just have the denser air effect then. Air density changes with temperature. Colder temperature means the air is denser. This means more air is entering the engine. In order to maintain the correct air fuel ratio, more fuel is added.
DannyW - It's still what Delta0 said -
I'm a Diesel owner too and seen about the same MPG drop off and the Mondeo forum I'm onn has lots of threads about the same thing. In the cold your MPG will drop, Ford gave a figure of 12-15% IIRC at temps of 5'c or lower (colder the temp the lower the MPG).
Left my 330d for over a week at under -20ºc in the alps and had a little trouble (ran rough for a minute or two) starting.
We won't get anything cold enough to cause problems.
Jesus you'd think it was "the day after tomorrow", as most are saying just get on with it.
The odds of the temperature outside getting that low are slim. The odds of the fuel in the tank getting to that temperature are even slimmer. The odds of it causing a problem are zero
Petrol engines warm up quicker than diesel engines in my experience.
When we had that REALLY cold snap a few years back -20? the derv went bad in the plant we where using on site (got me the day off :D)
this is a tdi
Yes they do. However during the warm up period a petrol engine will add more fuel. When the temperature is low then this takes longer. For a diesel the injection timing advances but no more fuel is used during cold weather. Diesel does take longer to warm up regardless of temperature.
Good to know.
At least I will be warmer quicker now than when we had our 1.9 tdi golf
The golf took forever for the heater to get warm.
