Looking to Buy New Desk for PC
20 Jan 2012
Divided Kingdom
am looking for a desk which i can use to put my 3x Consoles [2x xbox and ps3] and enough space for 3 monitors [1x 27" & 2x 24"]
been looking for one since few weeks and cant seem to find any good one.
Speakers.
I linked the desk here. The same desk is also on ebay... Somewhere.
Edit: Found it in my history but the seller has put the desk up from the roughly £120 i paid to £389.95. When I was looking for mine I googled for 'black glass desk' for hours.
That said the desk I have I don't think it big enough for 3 monitors etc... You should first have a think of how much space you actually need, get a width and depth that you think will do you.
thanks for the quick reply...
this is my current desk and i can add 1ft to this before it touches the radiator. current desk Dimensions (cm): W 120 x D 59.6 x H 74.1
http://www.amazon.co.uk/Alphason-Ma...=officeproduct&ie=UTF8&qid=1357356140&sr=1-88
on this at the moment i have 2 monitors i could probably put another but no space for consoles.
UPDATE: OK guys scrap what i said about the dimensions.. i can take even wider desk because i decided to change some things around the room.. so 1600mm?
one is for me and one is for my brother who will be using my old desk but his console will be on my desk if that makes sense.
Another here with a galant in black/brown, although it is the L shaped variant. Supports my 3 monitors fine, nice and solid construction too.
