Hi, I have a little problem with my sons PC.
It's running an Asus P8Z77-V LX. It has one HDD and one optical drive.
I built it late 2012,around November time. Been running smotth up untill just now.
When the PC boots up it goes staright to the BIOS. I then see the boot order is set to the disk drive and not the HDD.
I set it up so it boot from HDD,works ok so I recon nothing up with the MBR.
When the PC is powered down and left the problem starts again...
The board is brand new.
I was wondewring if the CMOS battery is failing would this cause the problem ?
And if the CMOS battery was at fault could there be a fault on the board which discharging the battery ?
I have another asus mobo which i could rob the CMOS battery from..
Or is there summet else I should be looking into...
Any help or advice please..
