- 13 Oct 2004
- Teesside
Hey all,
So i have an Asrock Z68 Extreme4 Gen3 Motherboard (http://www.asrock.com/mb/overview.asp?Model=Z68 Extreme4 Gen3) and have today upgraded to Windows 8.
My old soundcard that I used with Windows7 was a Razer Barracuda AC-1 Sound Card, which i bought around 5 years ago, and unfortunately is not supported in Windows 8, and so I have been relegated to the onboard audio.
I use a set of trusty Logitech Z-5500 speakers.
Can you advise if the onboard audio of my motherboard is any good? And if I wanted a new soundcard (which I do unless the onboard is decent) which would you recommend. I dont have a set budget, just after something thats good without being rediculously overpriced
Thank you!
Thank you!
